Trouble code/Too Lean
Old Feb 6, 2006 | 09:02 AM
minimotoman's Avatar
minimotoman
Well after installing my 17% pulley and 2% crank pulley on the rare occassion when on the highway I get the SES light, hooked up the OBD2 reader and I am running too lean(P0171) But that is only when I am on the highway and it is cool outside( <70F) If it is cool out and I am driving hard thru the backstreets I never get the light.
So I figure I need to remap the ECU whats the best way to do this without spending a fortune? I have tons of remapping experience on motorcycles and I do not like piggyback setups can I just remap the factory ecu and be done with it?
Suggestions Anyone?
Old Feb 6, 2006 | 09:06 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Start by getting a wideband O2 bung and seeing what you are actually doing for A/F, or at least a dyno run with a tail sniffer. Then you will know where you need to go.
You can adjust the A/F with piggy backs such as the Apex (which actually work well on this car - not sure what your past experience is with them). Doing it through the ECU can be done with Cartune, but it will depend on your car - it doesn't seem to work with the later cars.
Hope that helps!
Randy
Old Feb 6, 2006 | 10:25 AM
minimotoman
a/f meter
Would you have a recomendation on a wideband o2 kit?
Old Feb 19, 2006 | 06:38 PM
LordOfTheFlies's Avatar
LordOfTheFlies
Suggestions Anyone?
Before you spend oodles of money on a wideband o2 sensor, double check (and I mean *really* double check) that there are no vacuum leaks.
I was messing around doing the VGS install and got the exact same error code (P0171 - System Too Lean).
Turns out whilst putting my intercooler back together, I didn't do it correctly and thus had a leak on the right side of the IC.
So once again, double check your connections and make sure you reconnected everything back correctly first before shelling out the cash-o-la.
And so after reconnecting everything the code never came on again.
navybsn
Oct 5, 2018 04:42 PM
navybsn
Oct 4, 2015 03:27 PM
Tires, Wheels & Brakes
Sep 16, 2015 06:45 AM
Sep 14, 2015 12:48 PM
