Strange ticking
Old Feb 4, 2006 | 12:11 PM
rlfletch's Avatar
rlfletch
Strange ticking
My '05 MCS has developed a strange noise coming from the front end. It consists of a single, loud "tick" as I get on or off the gas at any speed up to about 35mph. Rolling or from a stop it doesn't relate directly to clutch position or gear chosen. It is becoming more consistent and a bit louder. Anyone else with this problem?
Old Feb 4, 2006 | 01:22 PM
Rossii's Avatar
Rossii
Do you hear it with the window up or down? Window down.......I know this might sound too simple but check your tire for stones. There could be a pebble or stone caught in your tread.
Old Feb 4, 2006 | 02:27 PM
rlfletch's Avatar
rlfletch
Nah, it's not a continuous ticking. Just a single tick with a distinctly mettalic tone as I get on or off the gas.
Old Feb 4, 2006 | 02:43 PM
effusant's Avatar
effusant
It could be as simple as a loose screw that fell into a body panel. Do you hear a slide then a tick? Do you have any way to pinpoint it?
Old Feb 4, 2006 | 03:00 PM
soofle's Avatar
soofle
I have had something similar for a while myself although for me its more of a knocking than a metallic tick. But otherwise same thing. Mostly in first through 3rd getting on or off the gas. Almost always at low speeds but occaisionally while going faster it shows up. As of yesterday it also happens when I first start the car (crank.. fire.. knock... normal running) interestingly i never hear it when in reverse and never as a result of braking. Only when going forward and only getting on or off the gas.
Old Feb 4, 2006 | 05:56 PM
XAlfa's Avatar
XAlfa
Bomb!! It's a God damned bomb!! Get the hell out of there!!!
Old Feb 4, 2006 | 06:30 PM
Smokey's Avatar
Smokey
Have you by chance placed anything, say the cigar lighter, into the ashtray?
Old Feb 4, 2006 | 08:50 PM
rlfletch's Avatar
rlfletch
Nope no roll and tick unfortunately. It is definately not eminating from the interior either. The fact that it is getting more prominate is concerning me but I'm sure it will completely dissapear as soon as I get within 100 yards of my dealer. I wonder if people who live as close to their dealers have problem free cars?
Old Feb 4, 2006 | 09:04 PM
schooner2's Avatar
schooner2
I had this same kind of ticking, i had the mini tec ride with me. he tightend the drive line bolt on the hub. its just one possiblilty, not saying its that for sure but after he tightened it, the tick went away, it was really strange. what you should do it go in First gear, and you start going pop the cluch in and out while in first gear and see if the tick happens when you start out quick and slow down quick, just in first gear, if it does then have the services check you drive line!! just an idea
Old Feb 4, 2006 | 09:07 PM
bdmini's Avatar
bdmini
that's a tough one. my '05 has a ticking noise upon acceleration, noticeable only w/ the window down (passenger side) and while the engine is still warming up. Most obvious on my particular hwy. on-ramp which is slightly uphill. It's weird, but seems to go away when the engine temp. reaches normal.
Sorry, not trying to hijack this thread. Sounds like it might be time to get to the dealer, gotta love oddball noises.
P.S. Have you changed out the brake pads??? Just a wild guess, but some aftermarket pads can move a bit in the calipers and cause a noise similar to that which you're describing.
Old Feb 5, 2006 | 01:41 AM
Tit's Avatar
Tit
AH HA!! How ironic...I just posted about this in mini2....
I have been having this problem and have been going crazy listening to it! I have finally noticed (duh!! I must be BLIND!) a whole lot of fluid burnt to parts of the engine bay - so I took some photos -
See Pics here
My knocking noise is exactly the same as you described. If anyone is troubleshooting their car, and wants to compare symptoms, mine are:
- a single knocking noise, when in gear, upon accellerating or taking pressure off accellerator.
- does not always happen, but happens often
- happens in all gears, usually when releasing the clutch into the new gear.
- It is more prone to happen in lower gears
- sometime does it on start-up
- does not do it in neutral
- engine shakes a bit more than normal on start-up
I have not confirmed that it is in-fact, the engine mount, but oil would not burn on hard to the metal like that, and there are no other sources of fluid in that area of the car. The car is going in tomorrow afternoon to be fixed.
Old Feb 5, 2006 | 05:40 AM
wildlifesc's Avatar
wildlifesc
The symptoms you describe seem to point to a broken/loose/missing motor mount...especially the last one about startup shaking. Hopefully your SA will find it...good luck.
Old Feb 5, 2006 | 08:04 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Check this thread out.
A bunch of people were having a very similar problem to you (myself included). Different diagnosis but usually the same fix. Replacement of a half shaft.
Old Feb 5, 2006 | 08:10 AM
dominicminicoopers's Avatar
dominicminicoopers
OK, turn off the TV, put down the remove and step away, step away.... You've been watching way too much "24" ...
Old Feb 5, 2006 | 09:52 AM
XAlfa's Avatar
XAlfa
Believe it or not, I don't own a television.
Old Feb 5, 2006 | 12:18 PM
C4's Avatar
C4
I knew it XAlfa... You are a caveman!
Old Feb 5, 2006 | 12:21 PM
XAlfa's Avatar
XAlfa
Yes, your modern world is very strange to me.
Old Feb 5, 2006 | 12:23 PM
C4's Avatar
C4
Tell me about it!
Old Feb 6, 2006 | 01:32 PM
rlfletch's Avatar
rlfletch
Thanks for all the links and info. I'll update if anything gets solved.
Old Feb 14, 2006 | 08:32 AM
soofle's Avatar
soofle
What is this drive line bolt you speak of? The knocking in my car has been getting slowly worse. It's now in all 6 gears, all the time, and every time I start the car. I'm gonna also be looking for any burnt on fluid like what Tit saw. Man I really hate having to bring my car into the dealer. Its not so much the two hour roundtrip cuz thats just an excuse to drive but these unpaid halfdays are starting to hurt.
Old Feb 26, 2006 | 07:36 PM
D_Nyholm's Avatar
D_Nyholm
Ok, i'll apologize first: THREAD HI-JACK!!
When I initially start the Mini, I hear a ticking noise that comes from the passenger rear of the car. It is steady and almost sounds like a blinker. It will go away after about 3-5 minutes of the car idling. At first I was thinking it was some sort of solenoid turning on and off, but I can't figure what it could be. I mean, the main electrical stuff back there is only the gas tank!!
Has anyone else experienced this? I'll mention it whenI bringt he car in for it's 10,000 mile checkup, but I just know i'll get a "can not replicate" answer from the dealer!!
Old Feb 26, 2006 | 07:43 PM
Far's Avatar
Far
Hey, aren't you like 10 minutes away from the Assael BMW? You should get it checked out, err doesn't seem to hurt...
Old Feb 26, 2006 | 08:44 PM
YYC's Avatar
YYC
Yep...ticking like a watch...exactly as you describe. I have asked about it before on NAM...no answers received!
Old Feb 26, 2006 | 08:47 PM
D_Nyholm's Avatar
D_Nyholm
did you ever ask your dealer about it? I just figure it is normal, I am really not too worried. The car still starts and runs fine!!
Old Feb 26, 2006 | 09:18 PM
JustGo4It_'s Avatar
JustGo4It_
Those pictures of the " burnt stuff " looks like cavity wax.
See Pics here
