Suspension Am I missing anything?
Old Jan 27, 2006 | 04:49 PM
K9MINI's Avatar
K9MINI
I have quite a list of parts to install before spring, all of them sitting in my office. So far I have 18" SSR GT1s , M7 springs (installed) , Alta adjustable control arms and end links, Wilwood 12.5 front and rear brake kits, Invidia Exhaust, and ????? I am going to re-install my back seats and sell my rear-seat delete kit.So I have one un-mod on the list.
I am thinking I should go for a sway bar since I will have the back end appart. Anything else I should consider adding to the list? I do all of my own installs so the time is on me.. I would like some input because I hate saying later on "I should have done....."
Old Jan 27, 2006 | 05:01 PM
saifa's Avatar
saifa
A rear sway bar would be my advice to you.
Old Jan 27, 2006 | 05:20 PM
Strom's Avatar
Strom
Why are you removing/selling the rear set delete?
Old Jan 27, 2006 | 05:35 PM
onasled's Avatar
onasled
Wilwood "rear" ?
The Alta rear control arms are a good thing, if you are doing all four.
The drop links are not really nesasary unless you have adjustable coilovers.
Yea, get a good rear bar. It should have been your first suspension mod anyway.
Have you done the pulley yet? This is a must, then a good CAI.
Old Jan 27, 2006 | 05:49 PM
K9MINI's Avatar
K9MINI
I had removed the rear seats the day I picked up my car and built a nice two door platform. I rmoved this setup and put the back seats in when I got my Sport Trac suv . Then I removed my rear seat again and installed rear seat delete panel . Well I miss the seats again and this set-up is not nearly as nice as my old hinged door set-up. Going to marketplace soon
Old Jan 27, 2006 | 05:55 PM
K9MINI's Avatar
K9MINI
Originally Posted by onasled
Wilwood "rear" ?
My car is a JCW and I have an Alta CAI in the car along with some other stuff. The Wilwood rear is the TCE setup with Wilwood hats, slotted and cross drilled rotors and re-location brackets. What bar would you recommend for this set-up? I am also considering going with coilovers....
Old Jan 27, 2006 | 08:03 PM
onasled's Avatar
onasled
Ok, figured it was the TCE rear kit, which actually is nothing Wilwood. Good setup.
At the moment I believe that the Bilstien PSS9s are the best street setup.
Personally I feel that the H-sport rear comp bar is the best.
I know see your mods listed.
Old Jan 27, 2006 | 11:37 PM
K9MINI's Avatar
K9MINI
Ok, figured it was the TCE rear kit, which actually is nothing Wilwood. Good setup. .
The hats are Wilwood and the rotors used in my set up are not the ones listed on his site.I will pm you the details if you like, we did something new lets say
Old Jan 28, 2006 | 04:04 AM
Stevie B's Avatar
Stevie B
Track maybe, certainly not street unless you like a hard ride. No matter how adjustable coilovers are, it's an either/or proposition. Either cornering or ride quality (which may not ever even be a good as standard). Of course, most people won't spend the money it they can't see the result, as in a lowered car. That's too bad for them 'cause they're missing out. Now if you're talking track cars, that's a bit different.
Old Jan 28, 2006 | 05:48 PM
meb's Avatar
meb
I've heard from a number of sources that the PSS9 set-up is incredibly comfortable - sources I trust - Onasled is one. A great deal of comfort, I suspect, comes from the progressive rate springs. FYI
Old Jan 28, 2006 | 05:51 PM
K9MINI's Avatar
K9MINI
Where can I find these? I wouldn't mind looking into them.
Old Jan 28, 2006 | 05:56 PM
onasled's Avatar
onasled
http://www.turnermotorsport.com/html...&subcat_id=125
Old Jan 29, 2006 | 02:14 AM
Stevie B's Avatar
Stevie B
I think that depends on how you have them set up. Great shocks no doubt, and if lowering is just something you're compelled to do, then that or the Koni coilover are 2 great choices. How unfortunate though, that once mounted, you can't see them anymore.
At some point, some smart MINI spring manufacturer is going to make a lowering spring specifically for the FSDs and clean up (one that lowers to the maximum capable and works with the dampening rates). M7, Alta, here's your opportunity...
Old Jan 29, 2006 | 06:12 AM
pooch1's Avatar
pooch1
Rear sway bar and adjustable control arms.
Old Jan 29, 2006 | 08:00 AM
K9MINI's Avatar
K9MINI
I ordered a Hsport rear bar last night from Webb motorsports (also a Pilo coil and Nology wires due to free shipping offer this weekend) and I have the adjustable control arms. I hope this rounds out my mods.....for now. I am going to need an install crew for this mod day. Thanks for your help everyone.
OutMotoring
Nov 16, 2015 07:04 AM
simo711
Oct 1, 2015 05:36 AM
tristanwelch95
Sep 30, 2015 08:58 AM
BackroadRunner
Sep 29, 2015 08:06 PM
smbmkay
Sep 11, 2015 09:45 AM
