heavy vibration under load
Old Jan 18, 2006 | 01:27 PM
ilscoobydooll's Avatar
ilscoobydooll
This started happening i would say about 2 months ago. Started happening right after i replaced the main motor mount. Getting a heavy steering vibration and it pretty much vibrates everything underload only. i know my clutch has been a little abused and trying to rule that part out. cause i don't see it happening from that. can this be the stabilizer mount at the top of the motor. ooo...btw the shifter also vibrates agressivley under load. please help....i am considering just gettin all the powerflex mounts....as anyone used these yet.....they are replacemts right they don't work with the factory mount. And my dam seats are squeeking....lol.....what kinda lube do you guys use to get rid of the dam noise. thanks guys.
Old Jan 18, 2006 | 01:33 PM
pooch1's Avatar
pooch1
You or the dealer replace.If dealer take back.
Old Jan 25, 2006 | 04:16 PM
ilscoobydooll
I installed the motor mount myself......it started happening right around that time from what I remember.
Old Jan 25, 2006 | 05:47 PM
RockC's Avatar
RockC
I suspect the motor mount you replaced. Last thing touched is first thing suspect when symptoms appear.
Motor mounts are tricky. I replaced a pair when I reinstalled a motor I rebuilt (a V8 pickup motor).
In installing the engine the engine mounts didn't quite line up but I levered things around and got the engine down on the mounts and the nuts on and torqued down.
Time passes. Pulled into a driveway and felt an odd thump and noticed engine running a bit rough. Pulled on into parking lot, stopped truck, opened hood and found engine mount had failed and engine had "hopped" off loose mount and was down in the engine bay.
I borrowed a jack and jacked engine up and over back on mount and managed to limp home where I replaced the mount with a new one.
The mount rubber block was under some torsional stress because of my misinstallation months before and this stress caused the rubber to separate from the plates that had bolts through them which fastened the mount to the chassis and the mount to the engine block.
Engine mounts are tricky... to install right.
Sincerely,
RockC.
Old Jan 25, 2006 | 05:56 PM
SpunkytheTuna's Avatar
SpunkytheTuna
Great response! Helpful, detailed, specific, and sensible.
You're going to have to stop doing that, you know.
Old Mar 4, 2006 | 07:39 AM
ltz_mtr's Avatar
ltz_mtr
any further word on this issue? Was it the mounts? Wondering because I have a similar situation.
Old Mar 5, 2006 | 05:19 AM
ilscoobydooll
i havent even gotten a chance to look at it. its been a little chilly up in the northeast lately. weather is breaking though so im gonna be checking it out this weekend hopefully i will let all u guys know what the solution was
shadtree
Cooper (non S)
Sep 8, 2016 12:02 PM
minieater
Oct 28, 2015 02:15 PM
Tires, Wheels & Brakes
Oct 1, 2015 12:18 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
