Drivetrain Hissing sound from engine, 'Winston' is Limp, Viagra not an option.
Old Jan 6, 2006 | 04:51 PM
BriNYU's Avatar
BriNYU
I just got my car back from Prestige via flatbed after they refused to deal with car, citing the mods. I have an EML and DSC light on (posted previously), causing the car to go into LIMP and idle yo-yo from 500-1500 as well as sputtering when i press accelerator.
I started it up to check it, and with the hood open, i heard a HISSING sound when the car would power down during the yo-yo idle. Could this be a big clue into my woes or is this normal? It would be a normal idle, engine sounding good...then all of a sudden a big power down sound and then a HISSSS.
Was wondering if anyone had any ideas. Thanks so much, Bri
ps- dr O i private messaged you this in case you didnt run into it in forums
Old Jan 6, 2006 | 07:40 PM
dkstone's Avatar
dkstone
As I said in your other thread, I had the same exact problem this past weekend had to have it towed to Habberstad, turned out to be a defective MAP sensor cost $43.50 .
Old Jan 6, 2006 | 07:45 PM
Gr8Force's Avatar
Gr8Force
Sorry I thought I had something there. Never mind.
Old Jan 6, 2006 | 08:53 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
I've seen the hose from the pcv valve go soft and collapse. It makes more of a honking noise. There was a recall on it.
If thats not, it look for a vacumm leak. It should not be hissing.
Old Jan 6, 2006 | 09:04 PM
J0kER's Avatar
J0kER
does this hissin' come from the front of the car? cuz i had the same kinda noise, a cracked intake pipe (from SC to TB) caused it
Old Jan 6, 2006 | 10:04 PM
TheBlackBrian's Avatar
TheBlackBrian
Just found the other thread...
Old Jan 6, 2006 | 10:17 PM
J Propane's Avatar
J Propane
Had the same problem putting the race car back together.
An intake runner/intercooler rubber boot was pinched from underneath.
JP
Old Jan 6, 2006 | 10:42 PM
minimc's Avatar
minimc
Is the hiss a continuous noise, or does it just stop? The S/C efficiency valve makes a hiss. ...A SSSsssss noise, as pressure is released at shutoff.
A lot of folks aren't familiar with the shut down hiss. Unless you're listening for it and the window's down you might miss it altogether.
If it's a pronounced but decreasing hiss, then its almost certainly the SEV - normal & unrelated
Old Jan 7, 2006 | 10:57 AM
BriNYU's Avatar
BriNYU
I'm not sure if that's what it was, it was happening as the car was idling and i was staring at the engine hoping to see something, anything.
'Winston' was just picked up by triple a and is now being flat-bedded to Eric over at Helix in Philly. I'm not sure when he'll be able to get around to it, but I have faith that he'll be able to figure out what the problem is and resolve it.
I will post results as soon as my MINI is fixed for everyone's reference just in case -god forbid - this problem should arise with a fellow NAM'er.
Thank you all so much for your input, I love the way MINI owners try to help each other out, like one Big MINI famlily
Old Jan 7, 2006 | 12:15 PM
jlm's Avatar
jlm
watch out for that un-scrupuluous Helix! it may come back with a new set of tranny gears, a turbo and capable of a 11 sec 1/4 mile. or maybe just some stickers about dog nuts.
Old Jan 7, 2006 | 12:25 PM
BriNYU's Avatar
BriNYU
I'll settle for a jersey, a six-pack of yards and a working car. But really, Eric, feel free to throw in the TurboCompressor kit, yanno, if you're feeling ambitious and what not, THAT would be the dog's cojones!
David.R53
Sep 1, 2015 06:49 PM
xpunisherx
Sep 1, 2015 11:47 AM
makg
Aug 21, 2015 02:49 AM
quickquest88
Aug 8, 2015 08:45 PM
