Interior/Exterior Light kit wire routing
Old Dec 29, 2005 | 08:43 AM
kapps's Avatar
kapps
Hi all. For those of you that have the Alta or Out Motoring lower grill light kits, how did you route the wires? I'm having a difficult time finding space to get the wires past the airbox/fusebox/ecu harness. Any help would be appreciated. Thanks.
Old Dec 29, 2005 | 09:12 AM
Battle Cattle's Avatar
Battle Cattle
well I have no idea how you would do it without atleast taking the stock airbox out. Because its solid and the ALTA is open enough to run wires...
-josh
Old Dec 29, 2005 | 12:08 PM
kapps's Avatar
kapps
Cool. Thanks! I got the airbox top and intake tube off and have enough room to get the wires under. I've found a good place to mount the controller and only need to drill a couple small holes in the plastic baffle behind that airbox to get the + lead to the fuse box bolt. Should be done tomorrow.
Old Dec 29, 2005 | 01:49 PM
kapps's Avatar
kapps
Ok, 1 more question. Where's a good ground...preferably in the middle or right section of the firewall? Do the bolts holding the PS fluid tank go to the firewall?
Old Dec 29, 2005 | 08:26 PM
Battle Cattle
no idea on the firewall... I used the one on the bonnet and the one infront of the ECU for ground. Anyone else?
-Josh
Old Dec 29, 2005 | 08:28 PM
not-so-rednwhitecooper
just ground it on the hood ground on the outer part of the front strut tower, unless you wanna use a zip screw into some sheetmetal somewhere.
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
