noise reported to be throw-out barring, how long until...
clutch failure? Will problems with the throw out bearing making that noise that people have described as the belt slipping sound, or the vibration noise have something to do with clutch failure?
If so, how long do I have until this happens? I was hoping I could have enough money to do the clutch/flywheel and a LSD unit all at the same time when the clutch needed replaced. I haven't had any problems with slipping or anything, seems to hold power just fine. I don't do regular burnouts, maybe 4 since I've owned the car, but do my fair share of spirited driving.
Depending on your year, Mini has bulletins out on this problem if its the same issues your having.
http://usminiclub.com/Forums/viewtopic/t=178.html 6-Speed
http://usminiclub.com/Forums/viewtopic/t=177.html 5-Speed
Originally Posted by andromcs
I have an 05 MCS Jan. build....would it have the new flywheel part #21-20-7-548-804???
Interesting that in 1FSTMINI's first link regarding the 6-spd Getrag....
"...I had my flywheel and clutch assembly changed and still have the same noise so now I'm hearing its "normal" "
Originally Posted by 1FSTMINI
No....mines a 6/05 and i have this problem....already changed the flywheel with the updated one and a new clutch and still here this until the clutch is depressed.
I think agile is talking about s problem .Yes it is common and is discussed in a current thread.Ive just finished having work done to address.The squeal is the throw out bearing,The rattle is the flywheel, which mini has changed under warranty because an update was available.It was replaced at same time because they dont want to go in 2 times to solve any noise type problems.When clutch disc was removed there was very little wear.
Thanks!
minipopkart
Aug 13, 2015 05:22 AM
