Bigger brakes & tires = less HP.
Old Dec 15, 2005 | 09:44 PM
goaljnky's Avatar
goaljnky
I was just watching some show on the Speed channel. The guys on the show were modding a Honda. I will skip the small details, but through trial and error they figured out that bigger/liter brakes and larger/lighter wheels/rubber actually ended up costing them five horse power at the wheels on the dyno. They did end up with slightly better times on the track due to better dynamics, braking, etc.
I just found it very interesting.
Discuss amongst yourselves.
Old Dec 15, 2005 | 09:49 PM
not-so-rednwhitecooper
Originally Posted by goaljnky
I was just watching some show on the Speed channel. The guys on the show were modding a Honda. I will skipo the small details, but through trial and error they figured out that bigger/liter brakes and larger/lighter wheels/rubber actually ended up costing them five horse power at the wheels on the dyno. They did end up with slightly better times on the track due to better dinamics, braking, etc.
Discuss amongst youselves.
I think it was an Acura.
Old Dec 16, 2005 | 02:57 PM
Crashton's Avatar
Crashton
Think of those 4 big wheels & tires as flywheels. You have to turn then which takes power. The bigger & heavier the more power loss. Your engine still makes the same power, but it's lost in the wheel/tires. One other thing, your braking will be affected to. Got to stop those big flywheels = longer stopping distances. All in all big wheels suck....IMO.
Chuck
Old Dec 16, 2005 | 03:23 PM
Dr Obnxs's Avatar
Dr Obnxs
Even if the wheels and tires don't weigh a thing...
the larger diameter has a longer lever arm, and the torque out the drive shafts (a constant) results in lower forces at the contact patch. So, if you have 100 ft-lbs of torque out the shaft, and a 1 foot radius, you "push" on the road with 100 lbs of force. If that's a two foot radius, you get 50 lbs of force pushing on the road, and half the acceleration (F=Ma).
Matt
ps, this is a well known effect, and why autocrossers don't run 18" wheels. Going to a shorter tire and wheel is "poor mans gear change".
Old Dec 16, 2005 | 04:11 PM
goaljnky's Avatar
goaljnky
Makes you think why one doesn't see 14, or even 13 inch rims for the mini.
Old Dec 16, 2005 | 04:35 PM
Crashton's Avatar
Crashton
Don't know for sure, but I'd bet they wouldn't clear the brakes.
Chuck
Old Dec 16, 2005 | 04:40 PM
Dr Obnxs's Avatar
Dr Obnxs
Also, you may scrape the bottom of the car.
Chuck
On the road. If a little is good, a lot may not be better.
Matt
Old Dec 16, 2005 | 08:31 PM
ScuderiaMini's Avatar
ScuderiaMini
all you 18" haters.....
woodstudio
Mar 15, 2020 08:28 AM
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
TJANK
Aug 24, 2015 06:11 PM
