Suspension End links and control arms
Old Dec 15, 2005 | 11:02 AM
mdsbrain's Avatar
mdsbrain
So I am thinking of replacing my end links with Alta ones and rear control arms.
Will the rear control arms allow me to correct the alignment of my rear wheels? Because right now they sit slightly cocked due to my H-sport springs.
Will I notice much a difference by changing my end links? I figure I will change all 4 (front and rear). I have a 22mm Alta in the rear and would like to take full advantage of it.
Old Dec 15, 2005 | 11:11 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
yes the control arms will bring your camber back into line.
no you don't need the end links as much, they will not hurt anything, but you could save a few bucks till you go big time race suspension.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Dec 15, 2005 | 11:13 AM
mdsbrain's Avatar
mdsbrain
Not much of a racer yet but I want to be I don't have the budget for another set of rims and tires. I just want to keep what I have working right for now.
Old Dec 15, 2005 | 11:15 AM
kenchan's Avatar
kenchan
id use that fund for endlinks towards tires.
Old Dec 15, 2005 | 11:16 AM
mdsbrain's Avatar
mdsbrain
You think the endlinks will make that little of a differnece?
Old Dec 15, 2005 | 12:06 PM
onasled's Avatar
onasled
Spend your money somewhere else. Save up for front camber plates first.
Old Dec 15, 2005 | 12:20 PM
kenchan's Avatar
kenchan
yep, little to zip unless you want to use the intermediate settings on an
adjustable swaybar.
Old Dec 15, 2005 | 12:22 PM
mdsbrain's Avatar
mdsbrain
adjustable swaybar.
Thanks for help guys I will look into getting the rear adjustable control arms.
Old Dec 15, 2005 | 12:36 PM
newbs49's Avatar
newbs49
Onasled and agokart.
Should he get just the lower rear adjustable. The uppers are for toe in if I'm not mistaken. No need to correct toe, that won't change with lowering springs or coilovers. Is that correct??
Old Dec 15, 2005 | 01:41 PM
Detroit Tuned
Vendor - 15 Years
yeah just lowers is all he needs to adjust camber.
mdsbrain-
take a look at my web site. we carry them all. 1 2 or 2.5 3
Old Dec 15, 2005 | 01:47 PM
onasled's Avatar
onasled
Rear toe can be adjusted on a Mini up at the trailing arm mount. Replacement of upper control arms would be for the porpose of getting a better bushing or hiem joint and weight savings.
Old Dec 15, 2005 | 02:59 PM
kenchan's Avatar
kenchan
mdsbrain-
does the toe change while he adjusts camber or has no ill effects?
Old Dec 15, 2005 | 03:30 PM
mdsbrain's Avatar
mdsbrain
Maybe if I help clarify why I want these parts you guys can help me to better understand.
I want the control arms to correct my rear wheels alignment.
I was going to get the endlinks to replace a relatively cheap part with a stiffer, stonger peice...if that makes sense.
Old Dec 15, 2005 | 03:43 PM
newbs49's Avatar
newbs49
mdsbrain
All you would need is the H-sport lower arms to get your rear camber back to stock or one of the recomended settings for auto-x or track. There is also replacement bushings that have camber adj. if you just want to do bushings.
Old Dec 15, 2005 | 04:03 PM
onasled's Avatar
onasled
There is nothing wrong with the stock drop links. They are not "cheap".
AND, hey, you have an '05? I believe that year has rear camber adjustment in the stock control arms.
Old Dec 15, 2005 | 04:07 PM
mdsbrain's Avatar
mdsbrain
First point...I'm no expert and bought stuff.
Second thing:
When I took my car for an alignment they said there wasn't enough adjustment in my 05 arms to make it right. Are they BSing me?
Old Dec 15, 2005 | 04:33 PM
newbs49's Avatar
newbs49
mdsbrain
Your dealer maybe right. I believe I read where the 05 only had .5 of a degree of adj.
Old Dec 15, 2005 | 04:45 PM
apexer's Avatar
apexer
Will someone please correct me if I'm wrong. Unless you are lucky enough that your springs allow your mini to be EXACTLY level, non-adjustable end links will pre-load the sway bar which will actually jack the corner weight. Adjustable end links will allow you to lenghten or shorten as necessary so that the antisway bar ends are parallel and unloaded. This may be only one or two turns in adjusted length but, that can eliminate as much as 320 lbs/inch preload.
When switching to lower springs, camber in front won't change but toe will change. In the rear, both camber and toe will change. Therefore, with lowering springs, its better to have both upper & lower rear adjustable control arms. This being said, many will live with the increased rear camber and just get one set to adjust just the toe.
Old Dec 15, 2005 | 04:48 PM
chows4us's Avatar
chows4us
Originally Posted by apexer
When switching to lower springs, camber in front won't change ...
This part I know isn't true. As soon as spring were put on, front camber went WAY off. So bad I considered camber plates but then they settled down (maybe thats needed) and all was OK.
Old Dec 15, 2005 | 04:59 PM
apexer's Avatar
apexer
I'll stand corrected. Just what Randy Webb told me.
Old Dec 15, 2005 | 05:10 PM
onasled's Avatar
onasled
Yes, front camber will change when lowered, but not so much that it should be a worry. If fact it should be for the better and in fact may be one of the reasons that people with lowered Minis feel such a handling improvement.
Toe will change in front and that should be checked. It will in fact 'toe in' which is the opposite of what you want.
Rear camber changes more as we know. Toe should not change I don't think. Problem with the added rear negative camber is that it will contribute to the understeer that we tend to want to get rid of.
Yes, if you wanted to balance the car out then it ALWAYS should have adjustable drop links. But being that the majority of street drivers won't note the difference, then it's not all that necessary until you get serious about racing and or install height adjustable struts.
Old Dec 15, 2005 | 05:12 PM
onasled's Avatar
onasled
Just don't know why this would happen. "Way Off"?
Old Dec 15, 2005 | 06:14 PM
kenchan's Avatar
kenchan
yes, the rear toe will be more suseptible to a zero to a slight toe-out
condition when lessening neg camber on the rear using just
the lower rods, but will not affect toe like on your other car which
has a very complicated multi-link suspension, ken.
Old Dec 15, 2005 | 06:16 PM
kenchan's Avatar
kenchan
maybe to him -1.5 is way off, where as we might prefer -2 on the front.
Old Dec 15, 2005 | 06:20 PM
apexer's Avatar
apexer
I haven't lowered my Mini yet so can't speak for sure but, back in the day when I changed the camber on my F/P MG Midget, I always had to adjust the toe. Was told then, and from what I have seen on other cars since, changing the camber, by what ever means, will change the toe.
