Old vs New OEM crank puley
Here are a couple shots of the new and old OEM pulleys. They are definitly different!
Although if you look at it there is very little dampening ( rubber ) on the new pulley
new is on the left.
new is on the left.
Crank Pulleys
Are they both from the same model car?
An MC has a single isolation crank pulley, but an MCS has a dual isolation pulley.
This was to move the resonance of the Super charger, drive belt and pulley to an rpm below the normal operating points of the engine.
John
John
I think the change to the lighter crank pulley was made in '05 -- here's an explanation from Randy Webb.
they are both for th esame car, just a new version vs the original one. If you go into the dealer and ask for a crank pulley you will get the lighter one as it has replaced the heavier one.
Personally I have tried the 3%, the 0% light and the lighter stock one and I perfer the lighter stock one, smoother throughout the range and idle is smoother. At least in my car, I have all the motor mounts upgraded with powerflex
11237514461
That is the ONLY part # for a crank pulley now. The old one was dropped and the number replaced the old one. I looked at an 02 and an 05 and they list the same # that I posted, and that is th eone that weighs 5.1#
ej
Nov 17, 2015 09:21 PM
M7Speed
Sep 3, 2015 07:48 AM
