Interior/Exterior Dash installation of MINI cuckoo clock?
Old Dec 4, 2005 | 06:43 PM
morknmini's Avatar
morknmini
In my car (2005) the clock is an alternative display to other info. To find out the time I press a button. It's easier to consult my watch. I just opened the MINI Motoring Holiday Gear 2005 mailer and saw the cuckoo clock. It's nifty! I can't justify spending $85 for a clock for home when sleek multi-function digitals are under $30, but that's not much money for an aftermarket gizmo for my MINI. I suspect if MiniMania offered an aftermarket clock for the MINI it would cost a lot more than that. The Holiday Gear mailer does not give dimensions, but it sure looks MINI-compatible. So I wonder if anyone in the NAM world has already installed the MINI cuckoo inside the car and has it worked out okay? Has anyone seen the cuckoo clock in the metal (or plastic)?
Old Dec 4, 2005 | 06:52 PM
mbabischkin's Avatar
mbabischkin
If it's the clock I think it is, I've seen it, it's very cool but I think it's probably too big to mount on your dash like you're thinking.
I believe that the large pod on the clock is a little smaller than the centermount speedo (probably about an inch smaller radius), while the smaller pod is about the size of the tach. Sticking the entire thing on your dash would probably take a good chunk of dash real estate and may also obstruct some of your view.
If it was the size of say the tach pod, it would probably be great for what you're thinking. But the MINI clock is intended to be a desk/shelf clock and is sized as such...
Old Dec 4, 2005 | 06:53 PM
PurplePeopleEater's Avatar
PurplePeopleEater
This is too bad, cause it sounds like a fun/silly idea... I would love to see something like that.
Old Dec 4, 2005 | 06:56 PM
morknmini's Avatar
morknmini
Yikes. It's not MINI-size at all. There went another money-saving idea (not many in the realm of MINIs). Thanks for the clarification.
Old Dec 4, 2005 | 06:59 PM
mbabischkin
Sorry
Just to be sure though you might want to take a spin down to your local dealer. A few of them have the clock on display either at parts or over in the showroom...
Old Dec 4, 2005 | 07:07 PM
morknmini's Avatar
morknmini
I think you're right. A clock the size of a softball would look ridiculous and, as you stated, usurp too much dashboard real estate. Because I kept thinking MINI I imagined it the size of a golf ball.
Old Dec 4, 2005 | 07:11 PM
gokartride's Avatar
gokartride
morknmini, you are crazy! I love it!!!
Old Dec 4, 2005 | 08:19 PM
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
The new clock location/configuration bothers me as well. I had grown to really like the location of the clock on my '02, which was above the rearview mirror. Glancing over at it allowed you to still have the entire road in your peripheral vision unlike looking for a clock low on a cluttered dash console. Having to hit a button only makes it worse.
So, after much searching, I got a Spot Clock by For Motion and stuck it to the rearview mirror. It is smaller than a quarter and, on these new oversized rearview mirrors, doesn't impact the rearward view at all.
I picked mine up from cbxman.com (as in Honda CBX, a motorcycle).
It works great - but I wish that it had reflective/luminescent hands or a light for low-light conditions. If I find one with that, I'll probably get a new one.
Old Dec 4, 2005 | 08:30 PM
Mini2Go's Avatar
Mini2Go
BTW, I almost forgot, for only a few extra pennies, there is a bigger color selection available directly at formotion.com
Here's a racy example:
Old Dec 6, 2005 | 05:43 PM
LordOfTheFlies's Avatar
LordOfTheFlies
I put a Volmeter in my passenger side a/c vent angled towards the driver.....
You could put an Autmeter clock in there with the same connections!
I was considering it...but I have an 04....so it's got a clock already....
Autometer clock:
Cost you asK? $70 or so for the gauge, $.20 for some ring terminals and a few feet of wire, and like $1.50 for some double sided sticky tape....oh and you might consider getting a 2 5/8" angle ring........
minicoclub
Nov 11, 2015 07:25 AM
kitty90034
Navigation and Audio
Aug 25, 2015 12:47 PM
minicoclub
Aug 25, 2015 09:07 AM
