Navigation & Audio Speaker Spacer Templet
Old Feb 11, 2003 | 10:41 AM
space's Avatar
space
I have done a search for this but have had no luck. Does anyone have a templet for the speaker spacer. I would like to build the spacer before tearing into my doors.
Old Feb 11, 2003 | 03:43 PM
Davbret's Avatar
Davbret
I think most of us just made the template from a piece of paper held against the door frame, so you can see where it can/can't go.
R
Old Feb 14, 2003 | 09:50 AM
davertrees's Avatar
davertrees
Good afternoon Space,
I have a drawing of the template you need. Problem is it's a mastercam drawing and you probably don't have a program that will read it. What I could do is fax the copy to you. You'd then need to check the scale against the dimension shown. Once you have that set, you'll have it. The upper holes and lower holes are on two different diameters around the center point of the speaker mounting hole. If you'd like me to fax the template, please give me a fax number. I can be reached directly at dvertrees@jlaudio.com.
Good luck,
Don Vertrees
Old Feb 14, 2003 | 10:00 AM
8ball's Avatar
8ball
Hi Don! ... your e-mail address didn't seem to work ...
.... but if you could send me the drawing file, I could try to convert it and offer scale drawings to MCO members ...
Thanks!
RCA@PXBYK.COM
YaTuSabe
Aug 23, 2018 11:41 AM
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
patsum
Oct 1, 2015 06:33 AM
Zew2888
Sep 29, 2015 08:49 PM
