Clicking noise on takeoff/brake
Old Nov 25, 2005 | 01:15 PM
nygaard's Avatar
nygaard
My 05 MCS has developed a "clicking" when I start to take off or begin braking (this happens both in a straight line and when turning. I jacked up the front left of the car and can reproduce the sound by trying to turn the tire/wheel by hand with most of my weight. It sounds like it is in the CV Joint, but unlike a classic CV joint going bad, I don't get the usual frequent clicking when turning. Anyone else have this problem?
Old Nov 25, 2005 | 01:29 PM
eVal's Avatar
eVal
Do you happen to have the web spoke wheels? I had seen people mention that as an issue with some of them and thought I saw that people had the offending wheels replaced under warranty (I think that it was caused by a problem in the fit of the two pieces that the wheels are made of).
Old Nov 25, 2005 | 02:07 PM
ministrone's Avatar
ministrone
I have had that problem and they first replaced the bearing, then the axle, first on the right, then the left.
Nygaard... Any relation to Peter? (I'm in Winnipeg)
Old Nov 25, 2005 | 02:53 PM
nygaard's Avatar
nygaard
eVal - I have removed the wheel and screwed the bolts in and using a bar to put rotational force on the axle, I can still reproduce the sound, so it isn't the wheels, unfortunately.
ministrone - did the axle replacement fix the problems? That is what I am leaning towards for diagnosis.
BTW - no relation to Peter
Old Nov 27, 2005 | 07:14 AM
element's Avatar
element
I think I am having the same issue. I can hear clicking in 1st gear when accelerating and braking... it sound like someone tapping on thin metal. I'll try your wheel test next time I have it in the air.
phil.
Old Nov 27, 2005 | 10:24 AM
ministrone's Avatar
ministrone
Yes changing the axle fixed the problem. The bearing change didn't fix it.
I knew it wasn't the tires as I had changed them to non-runflats with different rims.
I recently had the right axle done, as it made a more subtle clicking upon acceleration.
The loud metallic click was really prominent on the left side. Occasionally it still does, but only when I reverse, and not enough to warrant concern. Although my lease/warranty will be up in June so if I want to buy it out I'll be getting them to go over everything again.
Definitely a warranty issue. I've got a good relationship with my technician and I never get any runaround.
Hope that helps.
Old Nov 28, 2005 | 02:11 PM
eVal's Avatar
eVal
I thought this might help - found this Service notice on AllData:
M310105 JUN 05 Suspension - Front End Clicking/Creaking on Bumps/Turns
I do not have an account and access to the details, but it sounds promising, hope it helps - the "M310105" is the bulletin number that the tech can look up.
Old Dec 30, 2005 | 02:38 PM
nygaard's Avatar
nygaard
Looks like the dealer replaced the left axle to solve the problem. I haven't gotten it back yet to confirm - they are waiting for other parts for another minor issue.
Jake
Old Dec 30, 2005 | 03:22 PM
danielg's Avatar
danielg
Does it sound like two pool ***** hitting together?
This might help you: https://www.northamericanmotoring.co...ad.php?t=44291
It happend to me a in early September. You're welcome to read the entire thread, but the first post will give you the fix. I took my MINI to the dealer; the service guy just did steps 8 and 9:
8) Re-torque nut to 134 ft-lbs.
9) Tap lip of the axle-nut back into the indentation to lock it in place. Again...use a brass drift punch to make sure you don't damage
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
damncajun
Aug 17, 2015 08:25 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
nismo4life
Aug 5, 2015 08:31 AM
