Drivetrain P0108 overboost after new intake tube.
Old Nov 10, 2005 | 01:28 PM
autoxguy305's Avatar
autoxguy305
Well its official, the stock SC intake tube is garbage. I just finished making my new aluminum SC to throttle body intake tube and after getting it to seal correctly i took the car out for a run and had amazing results.
I've had my current mods (minus the new tube) for 15000 miles now. I've never gotten more than 18 psi out of it. When i went out for my first 5 minute run, i was able to pin my boost gauge 4 times. I have a 20 psi gauge. I do have a small problem though, i keep getting error code P0108. Its an overboost code.
Now before everybody goes crazy, i am only reading my boost levels from my autometer boost gauge. everybody knows that these are not the best so don't pay attention to the number that i'm posting, look at the delta between the original and n ew numbers. 18 -> 20 psi! that a delta of 2 psi! I plan to make a few more of these and test them on cars with different setups.
Old Nov 10, 2005 | 01:37 PM
MSFIT's Avatar
MSFIT
Thats awesome I want
Old Nov 10, 2005 | 02:24 PM
sfjames2's Avatar
sfjames2
good job man, I wish I could make me one of those.
Got any pics.? Wanna make me one???
....need to start spending money on tools instead of parts.
Old Nov 10, 2005 | 02:31 PM
autoxguy305
As far as pics go, till I have a few made, there will be none. I can't work really fast as i'm a one man show and i wouldn't want some big tuner shop to sell a bunch of these before i ever get mine out.
I feel the same way about mods and tools.
Old Nov 10, 2005 | 02:40 PM
sfjames2's Avatar
sfjames2
Handle it man, I'll be waiting.
Old Nov 10, 2005 | 02:44 PM
Wake|MCS's Avatar
Wake|MCS
I want one . If you need a test mule with mild mods, send one my way lol... Good job BTW
Old Nov 10, 2005 | 03:09 PM
F15EWeapon's Avatar
F15EWeapon
Not sure I understand what you're talking about that you fabricated... a custom intake? Where is the SC to Throttle body intake tube? Do you mean the tube with the little scoop up front that takes air to the stock air box?
I just want to understand what you're talking about. :smile:
Old Nov 10, 2005 | 03:26 PM
autoxguy305
Read through this and you'll understand.
https://www.northamericanmotoring.co...ad.php?t=54545
Old Nov 10, 2005 | 05:03 PM
jlm's Avatar
jlm
that's a problem the twincharger boys encounter as well. i think they put some sort of voltage clamp on the map sensor output.
Old Nov 10, 2005 | 06:40 PM
gmcdonnell's Avatar
gmcdonnell
Very cool! I want one! And I can think of at least 10 others in the Dallas club (MetroplexMINI.org) off the top of my head who will as well!
/gary mc
Old Nov 10, 2005 | 06:56 PM
JCampos's Avatar
JCampos
If I remember correctly, thats not an overboost code. Thats high manifold pressure.... I started getting this code once I threw on a 17% pulley and header. I also throw P0107, which is low manifold pressure. I throw these codes all the damn time so I doubt its your tube that is causing them. I run about 16-18 lbs of boost with a 17% pulley, AGS, and a nice whistling vacuum leak
Old Nov 10, 2005 | 07:12 PM
betet's Avatar
betet
Good job ... You might want to patent your design.... from the sounds of it , I think you will have a lot of buyer from the design, so you might be able to sell it to someone who can mass produce it, and make $$$ on each one..
///Gilbert
Old Nov 10, 2005 | 07:33 PM
autoxguy305
///Gilbert
I'm looking into doing that too.
Old Nov 12, 2005 | 06:27 PM
MSFIT's Avatar
MSFIT
bump...
Old Nov 13, 2005 | 06:20 AM
Bahamabart's Avatar
Bahamabart
looking forward to pics. How different is it from the Alta pipe?
Old Nov 13, 2005 | 10:31 AM
autoxguy305
you're thinking about the wrong tube, this tube is AFTER the throttle body.
Old Nov 13, 2005 | 10:34 AM
J0kER's Avatar
J0kER
:smile:.
Old Nov 13, 2005 | 10:40 AM
BigBrownDog's Avatar
BigBrownDog
So how would you differentiate this from the AGS tube? I know you said somewhere earlier in this thread or the other one that you didn't want to be drawing air from behind the radiator. Are you saying that your new tube allows the TB to remain in the same location so that the standard (or Alta, etc) intake plumbing can be used?
I always was curious as to why MINI chose to make that SC inlet tube the way they did -- I always assumed it was pinched because of necessary clearance in the cramped space down there. I've never had the radiator off (service mode) on my car to look at it in person, but I've seen pictures posted here on NAM. If you have a way to make your tube fit in the same space, it sounds like a winner to me!
Old Nov 13, 2005 | 10:53 AM
TonyB's Avatar
TonyB
BBD, it's my undrstanding that this tube is a direct replacement for the stocker, leaving the TB in it's current location. A very slick idea... Having it be aluminum, ultimately, will probably not be ideal though. The heat of the SC will be trasferred to it, and then to the TB... more so than if it were plastic or some other type of composite. This is along the lines of what Randy Webb found during his testing of the K&N intake tube (Typhoon)...
Old Nov 13, 2005 | 10:56 AM
Wake|MCS's Avatar
Wake|MCS
How's the 2nd tube coming along?? Any pics of either tube for us to peek at? If you were to make these in a limited number to sell, how much would it cost?
BTW, how's today looking for my pulley install
Old Nov 16, 2005 | 04:07 PM
1FSTMINI's Avatar
1FSTMINI
The 0108 code is going to come on from time to time with boost levels goin outside of the pressure sensors parameters. I reset my light every other week just to be sure nothing else tripped it.
Old Nov 16, 2005 | 05:36 PM
autoxguy305
fran, i've been busy with all of my projects and with moving my grandfather to his new house. If you want to stop by sometime to take a "peek" at the tube that'll be fine. As far as the pulley goes, i can't find my pulley removal tool so a new one has been ordered. Friday maybe.
Old Nov 16, 2005 | 06:08 PM
1FSTMINI's Avatar
1FSTMINI
You look alil late on those install dates. Take a ride to NY and ill hook you up.
Old Dec 13, 2006 | 07:06 PM
Motor On's Avatar
Motor On
Bump for pics.
Old Dec 13, 2006 | 08:31 PM
Wake|MCS's Avatar
Wake|MCS
Bump for where the hell is Nick (autoxguy305).. haven't seen him or his mini around miami..
