Suspension front suspension component torque specs needed
Old Nov 1, 2005 | 07:14 AM
wakaru mini
Guest
Posts: n/a
Does anybody know the torque specs for the following things for the front suspension:
1) top strut nut
2) sway bar endlink tie rod that connects to the middle part of the front strut
3) bolt that goes on the bottom of the strut
4) i think the wheels are 80ft/lbs and the three strut bolts that bolt to the strut tower are 25ft/lb correct me if I'm wrong.
Old Nov 1, 2005 | 12:37 PM
meb's Avatar
meb
Purchase a shop manual , you'll be happy you did. 80ft'lbs sounds very accurate for wheel lug nuts. That's what I use.
Old Nov 1, 2005 | 01:00 PM
chows4us's Avatar
chows4us
From Bentley
  1. Upper strut mount to strut shaft? 47 ftlb
  2. stabilizer bar link to stabilizer bar 41 ftlb (other one is also 41, replace self-locking nut)
  3. ?
  4. 25 lbs, correct, 80 lbs wrong, 89 + or - 7 pounds
Not sure if this helps
Old Nov 1, 2005 | 01:16 PM
meb's Avatar
meb
Chows4us,
I don't understand 89+ or - 7 ???
Old Nov 1, 2005 | 01:27 PM
chows4us's Avatar
chows4us
Originally Posted by meb
Chows4us,
Yup. Bentley says
"Torque wheel nuts when installing wheel. Wheel to Wheel hub: 89 + or - 7 ftlb"
I havent got the same character to represent plus or minus on the keyboard. So, it could be anywhere from 82 - 96 foot pounds
Old Nov 1, 2005 | 01:44 PM
meb's Avatar
meb
Okay, thanks. All four should be equal within that range nonetheless...to avoid warping rotors...
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
silence2-38554
Nov 12, 2015 09:39 AM
Minibeagle
Aug 13, 2015 10:00 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
