New rotors = new pads?
Old Oct 20, 2005 | 11:35 AM
efcmini's Avatar
efcmini
When you install new rotors do you have to also install new pads?
I had to order new rotors as my other ones (not stock) were warped. The info sheet that came with the new rotors says new brake pads MUST be used. Is this really the case or is it the rotor manufacturer trying to cover himself? My pads only have a couple of thousand miles on them. It may sound like I'm trying to be cheap about this but that really isn't the case, it's just that I don't want to have to sit around another week for new green stuff pads to arrive when I can just use my existing ones (if I get the okay from knowledgable people on here).
Thanks,
Ken
Old Oct 20, 2005 | 12:12 PM
keen's Avatar
keen
Re-use them. Obviously if your 3/4 of the way through a set it's a better idea to go ahead and replace while you have'm apart...but if they're still fresh, use them.
Might want to re-do the brake bedding process, and be sure you clean the cosmoline off the friction surfaces of the new rotors..
Old Oct 20, 2005 | 12:20 PM
DrkSilvrMini's Avatar
DrkSilvrMini
Just replaced my front rotors last nite, StopTech Rotors and EBC greens. Deffenately tell a difference in stoping power. Im very pleased with my results.
Old Oct 20, 2005 | 12:38 PM
BMDoubleU's Avatar
BMDoubleU
Thanks,
Ken
it is always better to buy new pads when changing rotors.. the new pad has to mate to the rotors.. your old pads have mated to your old rotors. old pads have grooves and other imperfections that make them less ideal for mating to the new rotor suface... (noise and uneven pad wear could be the effect)
good luck
Old Oct 20, 2005 | 01:17 PM
anteken's Avatar
anteken
Agreed, New rotors use new pads...also use the low-dust type....you'll be glad you did.
Cheers
Old Oct 20, 2005 | 01:50 PM
Dweezil's Avatar
Dweezil
If there is life left in your pads, there's nothing wrong with using them with new rotors. Replacing them is always a good option, esp since you've got everything taken apart while swapping rotors. But not necessary.
Old Oct 20, 2005 | 03:01 PM
chows4us's Avatar
chows4us
BMW says YES
People can have any opinions they want. If it were me, I do what the people who built the car says to do
Old Oct 20, 2005 | 03:11 PM
CDMINI's Avatar
CDMINI
The discs cost the $'s, not the pads, why not have a fresh brake system, bleed and/or flush the fluid as well? ALL NEW, now...
Old Oct 20, 2005 | 03:15 PM
bluesmini's Avatar
bluesmini
i've done it both ways. the car feels much better when you replace both the pads and the rotors.
Old Oct 20, 2005 | 04:42 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
When replacing rotors I always use new pads.
Sometimes I will replace worn (not too worn) pads with fresh pads and not change rotors.
Old Oct 21, 2005 | 07:54 AM
efcmini's Avatar
efcmini
Thanks for the replies people. Looks like the New Pads beat the Old Pads 6-1 with a streaker flashing his "I just got new rotors and pads" adding to the game's atmosphere.
I guess I'm waiting the extra week until my new green stuff pads arrive.
Thanks,
Ken
Doc Pain
Mar 10, 2021 04:50 AM
OutMotoring
Mar 3, 2017 06:29 AM
gnhovis
Sep 28, 2015 04:07 AM
