Suspension Alta Rear Sway maintenance
Old Oct 12, 2005 | 01:42 PM
Blue Brummie's Avatar
Blue Brummie
Two quick questions.
1. Is there anything special I should know about the lube for the sway bar, or can I just use general purpose grease ?
2. I've had to crawl under and tighten my rear sway bar twice in the last 12 months of driving (only 12K miles total). Is this typical ?
BB
Old Oct 12, 2005 | 01:56 PM
kenchan's Avatar
kenchan
1) I use white lithium grease. Make sure there's ample grease
on the bushings inside, outside, and bottom.
2) I've yet to have to re-tighten anything on my Alta 22mm..
ive had it for over 15k miles.
Old Oct 12, 2005 | 02:53 PM
D_Nyholm's Avatar
D_Nyholm
I've had sway bars on my other car for over 2 years and the lithium grease is still holding up fine with no squeaking.
As far as tightening them, I had to tighten mine 3-4 times in the first couple of months before I ended up using locktite on them to keep the nuts from backing off. Of course, this is a totally different car with different sway bars.
Old Oct 12, 2005 | 03:39 PM
rkw's Avatar
rkw
Blue Brummie & D_Nyholm:
How did you discover that you had to tighten them? Did you make a point of checking them or did they start rattling?
Old Oct 12, 2005 | 05:53 PM
D_Nyholm's Avatar
D_Nyholm
Correct, they starting making some knocking noises when you went over bumps. It was pretty annoying!!
Old Oct 13, 2005 | 05:15 AM
Blue Brummie
Yeah, it's definitely quite annoying. It starts off as a barely perceptible secondary bump after hitting a road imperfection (of which we have plenty in the Boston area) and steadily gets worse.
Oh well.
Hey Kenchan and D-, thanks for the tip on the lithium grease.
BB-
Old Oct 13, 2005 | 06:11 AM
garretwp's Avatar
garretwp
How do you guys like the alta sway bar? What size did you go with 22mm or 19mm? This is something I am going to change out in the spring and would like your input on the alta sway bar. I assume you used blue lock tight?
Garrett
Old Oct 13, 2005 | 06:22 AM
Blue Brummie
Well, I haven't had the chance to Auto-X since installing the bar, but I can tell you that in everyday driving, it's a hoot. I've got the 22mm and set on the middle setting.
I can say unequivocally that I am no expert, and I really don't have enough seat time in Auto-X to have "feel". But, I can tell you that I can definitely feel the impact of the stiffer rear sway bar. It definitely neutralized the behavior.
Definitely a worthwhile investment.
My $0.02 cents on installation. Be careful with the bolts on the rear sub-frame that hold the bar in place. If you don't get a clean thread alignment during the re-installation, you can damage the bolts. The threads are soft and strip out easily. I had to run around to 2 Home Depots to get new bolt and to find the right tap (just to be sure to have a clean thread on the sub-frame).
The Alta in general is the best IMHO, because of the performance, weight, and built in grease fitting to keep it running smooth.
BB
Old Oct 13, 2005 | 10:34 AM
kenchan's Avatar
kenchan
hey, how's that intake?
The 22mm on stiff setting is perfect with the H-Sport springs for street.
Garrett
Old Oct 13, 2005 | 11:19 AM
garretwp's Avatar
garretwp
The intake is great! I could not be more happy with it! Besides that was the first mod I had for the car even before I actually owned it. Thanks for the deal again! As for the sway bar this is something I will add in the spring as the weather over here is getting colder. I hate working on a car in the cold. Thanks for the info guys. Now back to our scheduled programming!
Garrett
Old Oct 13, 2005 | 05:08 PM
kenchan's Avatar
kenchan
cool!
yeh, if you're not in a rush no need to change it until it gets warmer.
Garrett
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
OZMDD
Aug 17, 2015 02:53 PM
OutMotoring
Aug 6, 2015 09:32 AM
