Interior/Exterior What gauges to add?
Old Sep 26, 2005 | 09:55 AM
PMC's Avatar
PMC
What gauges to add?
If you already have the oil pressure and boost gauges and want to add two more gauges, which would you get and why? I realize there may be differences based on street vs. track monitoring and the use of a NO2 system, but let's hear it.
Old Sep 26, 2005 | 10:29 AM
betet's Avatar
betet
I've added the following:
A/F gauge (I went wideband so this came w/ it , but seriously I've always found this gauge to be very essential in all my cars)
EGT gauge (temp of your internals are VERY important.. goes well w/ A/F as far as tuning for (lean/rich)..)
OIL temp
Water temp (don't like the fact that our water temp gauge is an "idiot gauge" in a sense)
///Gilbert
Old Sep 26, 2005 | 10:45 AM
RECOOP's Avatar
RECOOP
Oil temp 4+
EGT 3+
A/F (wideband O2) 3+
IAT 2.5+
Water temp 2+
Fuel pressure 1.5+
Intake manifold pressure 1.25+
Heads-up display 0 to 5+ depending on the pilot
Shift light 2 to 4+ depending on type of driving
Old Sep 26, 2005 | 10:53 AM
beken's Avatar
beken
oil Temp
Alternator.
fuel pressure
Old Sep 26, 2005 | 12:13 PM
JeffS's Avatar
JeffS
- Oil temp
- Water temp
A wideband is nice, but only if you have a way to tune with it. Plus, it's obviously much more expensive.
Old Sep 26, 2005 | 02:07 PM
chows4us's Avatar
chows4us
oil temp
volt meter
Old Sep 26, 2005 | 04:12 PM
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
I like the MINI Cooper Gague kit. Accessory gagues beside the Tach. I would like to get somethign similar for my MC But I don't need the boost gague. I was thinking of getting an Alta Gague pod and adding an Oil temp and Oil pressure gague.
Now where to find 60mm gagues with white face that lights up orange. Any thoughts?
Old Sep 26, 2005 | 04:14 PM
DrDiff's Avatar
DrDiff
Originally Posted by JeffS
- Oil temp
- Water temp
Isn't there a water temp gague on the speedo in the dash?
What is more beneficial oil temp or oil pressure?
Volts would also be a good choice. Monitor the condition of the battery.
Old Sep 26, 2005 | 04:17 PM
SpiderX's Avatar
SpiderX
If you make me choose I would go with pressure. with high temps you can still drive......no pressure shut it down NOW
Old Sep 27, 2005 | 06:23 AM
PMC's Avatar
PMC
Try egauges.com
Old Sep 27, 2005 | 06:47 AM
JeffS's Avatar
JeffS
That's just an idiot gauge. Factory gauges have a big deadspace around the "typical" needle position. They don't show increased temperatures unless there's a BIG problem.
Oil temp vs pressure... Remember, the purpose of gauges is to spot problems. That, however, implies that you're capable or willing to do something about the problem. In a street car, oil temps aren't of much concern. If you track your car though, a gauge might tell you that you need to get a better oil cooler, or make changes to one you've already bought. If you're not willing to spend the money or make the change though, you might as well not have the gauge. It's just there to look pretty at that point. With oil pressure, you don't have to do anything but turn the car off. For example... hit debris on road which cracks your oil pan. You see the oil pressure drop and cut the car off before your engine grenades.
Volts - the "I want a pretty gauge that's easy to hook up" gauge. Prettymuch like the non-wideband A/F gauge.
Old Sep 27, 2005 | 08:07 AM
Trickle X's Avatar
Trickle X
Egt
Guys running the EGT gauge, can you give me some feedback at the temps your seeing & where your probe is placed in the exahust...ie before cat or after, or in the cylinder downtube and if so which cylinder.
Thanks!
Old Sep 27, 2005 | 10:34 AM
DrDiff's Avatar
DrDiff
Try egauges.com
Thanks for the tip! Checked them out and they have a gague pod similar to the Alta gague pod. Alta is aluminum and will not warp in heat. I don't know what the Egague pod is made of.
Still floping back and forth Oil temp vs Oil pressure Still like the volt gague idea though.
Old Sep 27, 2005 | 11:31 AM
betet's Avatar
betet
Thanks!
I'll give you some answers hopefully in 2 weeks.. I have installed the gauge but the bung for my probe still needs to be welded in...
As long as you're not reaching 1600 F, it should be fine.
I'm going to tap in right after my 1st cylinder.. Some people claim 2nd cylinder gets hottest though.. But I've always tapped mine on the 1st cylinder.. The EGT should be installed at a location which is 1/2 the tube diameter from the head surface.. This is the standard location in the automotive world...
Hope this helps...
///Gilbert
Old Sep 27, 2005 | 11:50 AM
Trickle X's Avatar
Trickle X
Thanks Gilbert! I havent ever run a EGT gauge on a gasser, just diesels &* the rule of thumb there was 1300°F was safe pre-turbo. 1600 was piston melting range, how do gas engines differ?
Old Sep 27, 2005 | 12:15 PM
Trickle X's Avatar
Trickle X
Well here is a link, but doesnt really answer my question, but good insight on EGT.
http://www.sdsefi.com/techegt.htm
Old Sep 28, 2005 | 09:57 AM
betet's Avatar
betet
Great site..
Remember though, every car is different so the EGT temp will vary from engine to engine.. I'm sure manufacturers know what the limits would be..
Now if there is only a way to find out from a MINI mechanics..
I know w/ my turbo miata, I was seeing 1550 at WOT so I wasn't too concerned, my buddy's RX8 , 1800 would be a norm. =)...
Once I have my probe in, and my aftermarket parts, I hoping to see a number less than 1500 ...
///Gilbert
Old Sep 28, 2005 | 10:01 AM
J0kER's Avatar
J0kER
???isnt there allready a 'Thread' started on this very subject on here????
Old Sep 28, 2005 | 03:53 PM
NeilM's Avatar
NeilM
Beg to differ. I use the oil temp gauge in both my cars every single time I drive, street or track. It's what tells me when the engine is warm enough to drive it hard. Until then I stay under 4K rpm and use only part throttle.
Paradoxically the oil pressure gauge is less useful, because the chance of my actually looking at it when the worst happens is about zero. Rely on the idiot light for that. Then the gauge just confirms the bad news.
Neil
05 MCS - bone stock
96 M3 - not bone stock
Old Sep 28, 2005 | 04:01 PM
qweewq12's Avatar
qweewq12
boost - good to have with lots of mods and a boost controller - good to know what psi your taxing the engine with.
oil pressure - good to know that the oil pump is working good....
oil temp - good to know if engine is warmed up for abuse.
egt - exhaust gas temp... good to know how hot...
voltmeter - good to know battery level.
egr - neat, but junk...roams too much, unless you are at WOT... used more for oooh-aaahh with the bobbing lights...
Old Sep 28, 2005 | 04:04 PM
DrDiff's Avatar
DrDiff
What we need is a group buy on the gagues and gague pod!
Old Oct 4, 2005 | 10:54 AM
J0kER's Avatar
J0kER
oil temp. would be the most important in my book, cold weather for sure!! but i agree w/u about the pressure guage.....
Neil
05 MCS - bone stock
Filmy
15
Jun 6, 2023 06:27 AM
dinomaniac
Sep 18, 2018 04:19 AM
Oct 19, 2015 08:07 PM
FLKeith
Sep 13, 2015 08:08 PM
Gen1Parts
Sep 7, 2015 01:37 PM
