Interior/Exterior Installing M7 Front Splitter -need advice
Old Sep 22, 2005 | 06:40 PM
red rage's Avatar
red rage
Hi,
I am installing the front splitter but need some guidance:
1. The holes for the stainless supports are NOT drilled, any advice on where to drill them ? What size drill-bit ?
2. The outermost, lateral portions of the splitter attach very close to the 2 screws that anchor the lower front arches, should I leave them in place or remove one?
Thanks,
Phil
Old Sep 22, 2005 | 06:47 PM
Morales's Avatar
Morales
Here's where I put mine.
Attached to the bottom of the license plate frame. Been there for over a year. No problems.
Old Sep 23, 2005 | 06:40 AM
red rage's Avatar
red rage
Looks GOooD..... BUT I don't have a front license plate ....
Old Sep 23, 2005 | 11:43 AM
Vinyl Styles's Avatar
Vinyl Styles
Try contacting SFjames2, his looks great, and is very strong by having put some fiberglass support behind the bumper.
Old Sep 23, 2005 | 11:54 AM
J0kER's Avatar
J0kER
its best to ask Randy or Peter since their the innovators but i've installed them right in between the lower grill & next to the fogs....at an angle
Originally Posted by red rage
Hi,
Thanks,
Phil
Old Sep 23, 2005 | 11:58 AM
MSFITOY's Avatar
MSFITOY
Right-about-there...
Use SS washers on both sides of the bumper skin and it will be just fine:smile:
Old Sep 23, 2005 | 12:03 PM
JCW Driver's Avatar
JCW Driver
Here's mine
I just measured out and up from centerline, and marked with masking tape. Then drilled carefully. I concur with MSFITOY's comments about washers...
Oh, and USE THREADLOCK!
Another view:
Old Sep 23, 2005 | 12:44 PM
sfjames2's Avatar
sfjames2
Hi,
Thanks,
Phil
I took the screws out and ran a bolt all the way thru, topped with a locknut. I made mine as tight as I could by buying extra SS nuts and bolts, used 6 all the way across.
Lagston verified a sturdy M7 splitter fit at CA Hwy. 5 speeds.
Old Sep 23, 2005 | 12:50 PM
JCW Driver's Avatar
JCW Driver
PS...
I've had no issues with mine, and run it on the track at 110 mph, with no problems.
Old Sep 23, 2005 | 12:54 PM
MSFITOY's Avatar
MSFITOY
I know it hold at 130+
Old Sep 23, 2005 | 01:02 PM
sfjames2's Avatar
sfjames2
Sick man....
Old Sep 23, 2005 | 01:16 PM
VoiD's Avatar
VoiD
Does the splitter not have holes in it?
Looks like MSFITOY and JCW Driver have the holes on difference places.
Old Sep 23, 2005 | 01:34 PM
crazyaboutmini's Avatar
crazyaboutmini
did anyone tried drilling the holes on the black plastic lip thingy to give it more leaner subtle look. or can you hook the splitter without the hinges like the splitter aston martin gave the vanquish s?
Old Sep 23, 2005 | 03:13 PM
m332is's Avatar
m332is
Not to hijack this thread, but with the push (understeer, tight, etc. - pick your term) in these cars, do you really want/benefit from more downforce upfront?
Old Sep 23, 2005 | 03:32 PM
red rage's Avatar
red rage
At high speeds, without hitting the brakes to shift the weight to the front of the car, yes, it will help lessen the understeer
At full throttle and speeds, the front can get pretty light
Old Sep 23, 2005 | 03:35 PM
red rage's Avatar
red rage
I may try it without the bling support bars,
by reinforcing it, adding a couple more bolts to the center areas, off midline and slightly more forward than the other 6
Old Sep 23, 2005 | 03:41 PM
sfjames2's Avatar
sfjames2
red rage, be careful using it w/o the supports. The splitters used without those braces are waaay stiffer and 1/2 inch thick ours is soft and nowhere near as thick as it would need to be. Might have it fold underneath or look lame getting pushed down while your motoring.
Old Sep 23, 2005 | 05:29 PM
red rage's Avatar
red rage
OK, I will test it first, then install it if need be ....
Still not sure what is the best mounting point, I will improvise
BTW, I did remove the back screw on the bottom of the front wheel arch and went thru the same hole with the bolt for the far lateral mount, connected to the other plastic pieces too
Old Sep 23, 2005 | 05:37 PM
J0kER's Avatar
J0kER
NO! on the holes!!
Old Sep 23, 2005 | 07:37 PM
MSFITOY's Avatar
MSFITOY
Push is not good...front down force reduces push = good
Old Sep 24, 2005 | 07:26 AM
red rage's Avatar
red rage
Here she is , sans braces
Old Sep 24, 2005 | 07:30 AM
J0kER's Avatar
J0kER
Old Sep 25, 2005 | 12:07 AM
crazyaboutmini
thats so nice and clean , now you have to share with us how it was done
Old Sep 25, 2005 | 01:39 AM
MiniBH's Avatar
MiniBH
Looks pretty good! Any idea on where I can buy the splitter online?
Old Sep 25, 2005 | 01:43 AM
JCW Driver's Avatar
JCW Driver
www.m7tuning.com
