help me understand
Old Sep 18, 2005 | 06:20 PM
rrdusek's Avatar
rrdusek
help me understand
i think the offset for s-lites is 50, is that correct? so does a wheel with a 45 offset move the tire more towards the center of the car? if so, should you use spacers to get it back to where it was?
Old Sep 18, 2005 | 07:53 PM
Hammer's Avatar
Hammer
Here is everything you ever wanted to know about offset
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Sep 18, 2005 | 11:57 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
rrdesek,
S-lyte wheel offset is +48mm.
A wheel of the same 17x7" width and +45mm offset would move the wheel slightly away from the center of the car.
As wheel offset approaches smaller numbers and if the MINI has a lowered suspension then there is risk that the outer edge of the tire will rub the inner rear wheel well plastic.
For a MINI with stock suspension, wheels of +37 to +50mm offsets will usually not rub. For a MINI with a lowered suspension, wheels of about +42 to +50mm offsets will be OK but it may vary with the type of springs you install and the outer tire diameter used (smaller than stock sized tires will tend to rub less or not at all).
See
https://www.northamericanmotoring.co...ad.php?t=42106
Also search for "offset".
Old Sep 19, 2005 | 05:40 AM
rrdusek's Avatar
rrdusek
thanks
thank you both for the articles. they had alot of good information.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
GAT
Oct 4, 2015 07:27 PM
bradstyle
Oct 1, 2015 11:15 AM
BushOner
Sep 29, 2015 08:42 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
