Drag Wheels
Old Sep 12, 2005 | 08:03 PM
rcman's Avatar
rcman
Drag Wheels
Has anyone had any experience with Drag wheels. I am thinking about the DR3. Thanks in advance Scott
Old Sep 13, 2005 | 05:16 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
17 or 18" Drag Rims
OK- last post edited.
Looks like the Drag rims are ok in both 17x7 and 18x7 sizes
4x100 bolt pattern
73mm centerbore (hubrings recommended to fit 56.1mm MINI hub)
+40mm offset (will fit stock MINI suspension but might not do as well with a lowered MINI- likely some rubbing in the rear wheel wells).
http://store.racinglab.com/drwhdr3tuwh1.html
Not sure of the weight. Doesn't look too light.
$450 a set of 4 in 17x7 and $540 a set in 18x7 plus shipping $70.
Comes in Black, gun metal or silver finishes.
Old Sep 13, 2005 | 06:40 PM
kyriian's Avatar
kyriian
Originally Posted by minihune
see
https://www.northamericanmotoring.co...ad.php?t=43035
See BFG Drag Radials from tirerack.com- check with Alex
http://www.tirerack.com/tires/tires....FA+Drag+Radial
Some sizes will fit for the MINI
I think he's talking about a brand called DRAG....
http://store.racinglab.com/drwhdr3tuwh11.html
Old Sep 13, 2005 | 08:13 PM
rcman's Avatar
rcman
You are correct those are the wheels I was looking at. only in 17x7 will 40 offset be ok?
Scott
Old Sep 13, 2005 | 11:13 PM
minihune's Avatar
minihune
Scott
See post #2 in this thread.
+40 offset is OK with stock suspension in either MC or MCS.
Use stock tire 205/45-17 for best clearance.
Optionally you can also consider 215/40-17 (slightly smaller outer tire diameter than stock) or 215/45-17 (slighter larger than stock).
Once you lower your MINI you will have less clearance in the wheel wells and some trimming with a dremmel tool might be needed when using 215/45-17 tires.
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
PelicanParts.com
Aug 25, 2015 02:46 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Chippawaguy
Off-Topic :: Autos
Aug 19, 2015 11:30 AM
