Boot light on
Old Sep 11, 2005 | 03:20 PM
ArmyDog's Avatar
ArmyDog
Coordinator::Asia
Boot light on
My boot light won't go out. The boot is closed and locked. Where is the sensor located on the boot? The BMW service department here sucks as I would have to leave my Mini there and wait for them to look at it...and that could be days. Any help is appreciated.
Old Sep 11, 2005 | 03:26 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Try the bonnet. They are the same light, and maybe it was open or ajar for some reason. Let me know if that doesn't work...
Randy
Old Sep 11, 2005 | 03:28 PM
ArmyDog's Avatar
ArmyDog
Coordinator::Asia
I checked the bonnet twice.
Old Sep 11, 2005 | 03:32 PM
not-so-rednwhitecooper
its built into the latch.
pull off the panel across the back to access it.
Old Sep 11, 2005 | 03:35 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
You will most likely have to replace the latch then. You can trace the problem to it with a test light. It is right in the middle of the boot, and you will have to remove the trim bit to gain access to it.
Hope that helps!
Randy
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Just saw Rick's reply - sorry if it was redundant!
Randy
Old Sep 11, 2005 | 03:36 PM
lotsie's Avatar
lotsie
Is just the light in the boot on, but not the overhead light?
Both go off when I lock the car with the remote, even with the hatch open.
Old Sep 11, 2005 | 03:38 PM
ArmyDog's Avatar
ArmyDog
Coordinator::Asia
It is the "dummy" light on the speedo that is lit.
Old Sep 11, 2005 | 03:44 PM
the bonnet switch can easily pop out, make sure it is securely fitted into the slot and popped in, it slips out if you slam the hood hard sometimes.
the boot switch is easy to get to. i dont think a new one would be expensive for either boot or bonnet.
Old Sep 11, 2005 | 04:10 PM
ArmyDog's Avatar
ArmyDog
Coordinator::Asia
Just took a short break from work to check the switch/locking mechanism. I took a screwdriver and adjusted the mechanism housing and also sprayed some WD40 on the lock....and presto.....the light went out. So I guess the mechanism had moved or slipped out of position or the contacts were dirty.
I appreciate everyone's assistance. :smile:
So add this little fix to your "fix it" notes.
Teh
Jun 13, 2018 02:59 PM
Chasp
Aug 22, 2015 01:27 PM
nismo4life
Aug 5, 2015 08:31 AM
