R50/53 Cold Tire Pressure: How Far/Time or Distance till air heats up and how much?
Old Aug 29, 2005 | 01:15 PM
DoubleNick's Avatar
DoubleNick
Does that make any sense? Basically, I measure the air pressure in my garage after the car has not been on the road--say for 24 hrs. Where I go to add air is approximately 3 miles from my house. How much should the pressure increase? How much is ambient temperature a factor, 95 vs 45 degree day? Thanks to you tire engineer types who know these kind of things. Nick
Old Aug 29, 2005 | 01:25 PM
Yucca Patrol's Avatar
Yucca Patrol
  • n = number of moles
  • R = universal gas constant = 8.3145 J/mol K
  • N = number of molecules
  • k = Boltzmann constant = 1.38066 x 10-23 J/K = 8.617385 x 10-5 eV/K
  • k = R/NA
  • NA = Avogadro's number = 6.0221 x 1023 /mol
This is what a physicist might tell you. The ideal gas law expresses the relationship between pressure, volume, and temperature of a gas.
Assuming that the volume of the tire is constant, your pressure after driving is related to the change in temperature, but of course you know that . .
So, what we need to do is calculate the pressure change that occurs when the temperature changes. Give me a few minutes and I'll have a number for you
Old Aug 29, 2005 | 02:32 PM
lcubed's Avatar
lcubed
  • k = R/NA
unfortunately, the ideal gas law doesn't really apply when water moisture
is present in the mix. that's why those dreaded steam tables exist in the
back of thermodynamics texts for Mech Engr.
replacing the tire gas w/ nitrogen leads to more 'ideal gas' like behavior.
Old Aug 29, 2005 | 02:34 PM
kenchan's Avatar
kenchan
basically 1psi difference for 10 degrees change in ambient temp.
i recommend you just buy a air compressor ($25) and pump in your garage.
Old Aug 29, 2005 | 04:16 PM
VoiD's Avatar
VoiD
just add 2-3 more psi, come back home, let it sit overnight and bleed air next day.
Old Aug 29, 2005 | 05:18 PM
Red's Avatar
Red
Best idea for us non math majors!
regards,
Red
Old Aug 29, 2005 | 05:29 PM
Yucca Patrol
Was wondering if someone might point that out!
Plus, the ideal gas law won't work with a nitrogen inflated tire either, since the volume of a tire is related to the pressure because rubber tires are not rigid and the volume is affected by the weight of the car. . . .
Power outage due to the hurricane kept me from getting back to post some numbers, but as stated before, 1psi per 10'F is good enough of an estimate for most of us. . .
Old Aug 29, 2005 | 05:32 PM
LAMINI's Avatar
LAMINI
Most Gauges
have a margin of error so just add accordingly for that error. For example mine differs by 5 so instead of leaving them at 35psi, I go to 40psi.
Old Aug 29, 2005 | 05:55 PM
lcubed's Avatar
lcubed
the dry nitrogen is so that as the tyre heats up due to rolling, a linear pressure increase occurs.
(tyres w/ 'wet' gas mixture heats up along a nonlinear curve and
will likely have a much higher pressure at the
same temperature than one filled w/ 'dry' nitrogen.)
btw, the old rule of thumb :
more than 1/4 mile of slow driving, the tyre ain't 'cold'
Old Aug 29, 2005 | 07:08 PM
daleCarlsbad's Avatar
daleCarlsbad
Nitrogen is the “only” way to go if your fanatical about tire pressures. Check-out the pit lane at any race track........
It is much more consistent (when heated) and your tire pressures will remain constant over a greater length of time.
I purchased my set up for the racing karts (running 12 psi) where +/- 1 psi is critical to grip and handling. I use nitrogen in all my vehicles and no longer have to “top-up-the-pressure" every couple of weeks. Best $300 spent.
And yes the Mini does handle like a kart....well sort of but the shifter kart is awhole lot more fun at 125 mph.
Old Aug 29, 2005 | 07:12 PM
whovous's Avatar
whovous
Check the air pressure when the tires are cold. Drive a goodly distance, until the tires are "hot." Check the air pressure again. Determine the difference between the two.
Next, decide what you want the cold air pressure to be, whether by reading the side of the tire, or some more involved method. Add the difference determined above to your ideal cold air pressure, and you will have the number you need for "hot" inflation at the air pump.
Or spend $20 or so at WalMart for a cheap air compressor, and fill your tires at home when they are cold. I got one when I ditched my run flats, and it comes in handy some times.
Old Aug 29, 2005 | 07:14 PM
VoiD's Avatar
VoiD
how do you fill up an inflated tire with nitrogen? Do you need one of those wheels with two valves or is there a special trick?
Old Aug 29, 2005 | 07:23 PM
daleCarlsbad
Never seen a wheel with two valves.
I just pop out the needle valve, release all that poo poo air, and fill 'er up with the good stuff.
Old Aug 29, 2005 | 07:41 PM
kenchan's Avatar
kenchan
ever heard of Kosei?
Old Aug 30, 2005 | 05:19 AM
DoubleNick's Avatar
DoubleNick
Thanks for all the info
NAM is a great place. Great info. I got lost on the technical formulas--but hey, I still haven't figured out where the two trains will meet when 1 leaves Chicago at 1000AM going 80 MPH and the other leaves Denver--well you know the deal.
I think I am going to buy the compressor. Thanks again. Enjoy your journey. Nick
Old Aug 30, 2005 | 07:31 AM
Gr8Force's Avatar
Gr8Force
formulas...nitrogen...ow! ow! I've gone blind!
I got that cheap-o $15 compressor from WalMart. It takes more time to get the air in the tire than a fancy-schmancy compressor but I still get the right pressure.
Old Aug 30, 2005 | 09:24 AM
kenchan's Avatar
kenchan
yeh, air is free. free is good.
having an accurate (consistent) pressure guage is important too.
me? I use a pen type guage I bought years ago before stores
started to sell its crap versions.
Old Aug 30, 2005 | 02:31 PM
lcubed's Avatar
lcubed
lots of tyre places around this neck of the woods offer nitrogen fill.
(even the costco!!)
woodstudio
Mar 15, 2020 08:28 AM
W0TM8
Dec 19, 2019 07:50 AM
Powershift
Aug 16, 2015 05:14 PM
JamJam43087
Aug 16, 2015 02:02 PM
