Interior/Exterior passenger seat comfy, driver seat not so comfy!!
Old Aug 28, 2005 | 07:01 PM
willymcd's Avatar
willymcd
there is a difference between my driver seat and passenger seat in the lumbar region. the drivers seat is stiffer and seems to push out harder on my lower back then the passenger seat does, and this is just not me either, my folks totally felt the difference and Juan my MA even could feel it a little bit. What should i t do about this? the seat does bug me a bit but i guess it might get better or i will get used to it oh yeah i have the leatherette seats!
another question, i here a high pitched drilling type noise when i am at a stop, i think it is the power steering because it gets louder when i turn the wheel, but should the power steering be making noise when i am not moving and am not touching the steering wheel?
Old Aug 28, 2005 | 07:51 PM
kaelaria's Avatar
kaelaria
I know mine feel the same...are you sure you have them adjusted exactly the same in all regards?
MINIclo's Avatar
MINIclo
7th Gear Gal
*****, I wonder how difficult it is to swap the seats? Maybe that would work for you? And the sound you are concerned about, is it sort of like a dolphin sound? If it is, that is the classic MINI whine and nothing to worry about.
Clover
Old Aug 28, 2005 | 08:20 PM
Moneypenny's Avatar
Moneypenny
question on the seat swapping, if he did that, wouldn't the side airbags then go inward?
I don't know if he could do that....
-Sarah
Old Aug 28, 2005 | 08:41 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
-Sarah
Doh! Of course! Silly me.....thanks for catching that, Sarah!
Clover
Old Aug 28, 2005 | 11:51 PM
willymcd's Avatar
willymcd
i wish i could swap the seats around, but those darn airbags! lol... and yes i made sure that both seats were adjusted the same time when testing the two.
Old Aug 29, 2005 | 06:26 AM
kaelaria's Avatar
kaelaria
Then take it in, something is broken.
Old Aug 29, 2005 | 08:18 AM
UUNetBill's Avatar
UUNetBill
I might be restating the obvious, but make sure that the lumbar ***** are both set the same, i.e. crank 'em all the way in/out and try it again. I know I can feel a definite difference in mine when the **** is cranked in or out, and with the lumbar adjust ***** on the inside of the seat, it's easy to crank one in and the other one out. . .
Just a thought. . .
Old Aug 29, 2005 | 08:37 AM
kaelaria's Avatar
kaelaria
He doesn't have lumbar.
Old Aug 29, 2005 | 09:33 AM
UUNetBill's Avatar
UUNetBill
He doesn't? Did I miss something? I don't see where he says what model/packages he has. . .am I just getting old?
Old Aug 29, 2005 | 09:40 AM
chrisneal's Avatar
chrisneal
No lumbar adjustment on the leatherette seats.
willymcd, I think your MA was wrong in not offering to have this fixed right off the bat. Of course there shouldn't be a noticeable difference in the seats! Good luck!
Old Aug 29, 2005 | 09:42 AM
chrisneal's Avatar
chrisneal
By the way, this thread should be moved to MINI Talk...
Old Aug 29, 2005 | 09:56 AM
UUNetBill's Avatar
UUNetBill
Ah-hah! You, sir, are correct. It IS old age creeping in. . .
sevin
May 2, 2026 06:11 AM
W0TM8
Dec 19, 2019 07:50 AM
Aug 24, 2015 03:14 PM
messyjesse96
Aug 12, 2015 05:51 AM
