Suspension Installing the Bilstein PSS9 soon,need some advise on alignment...
Old Aug 23, 2005 | 07:44 PM
ilovepanerai's Avatar
ilovepanerai
Hi all,
I will be fitting the Bilstein PSS9 soon, just like to get some pre advise on the best alignment specs after the fitting:
On the handling side of mods, my car is fitted with the following:
1)H-sport 25.5mm comp sway bar
2)H-sport rear lower adjustable control arms(1 pair)
3)Bilstein PSS9 coilovers
I am looking to lower the car 1.1 to 1.2 inch all round(front and rear)
from stock height.
Can anyone advise what would be the best alignment specs for my installed parts above(i.e. front and rear toe,camper)
I do understand that I will not be able to adjust much on the front toe and camber, and the rear with only a pair of H-sport adjustable arms, only camber is adjustable.
I just like to get some the best obtainable alignment setting in this setup.
Just to add, I will not track the car, just that I like to have best optimum handling during my hard road driving...
I will be looking to add adjustable end links and another pair of H-sport adj arms once I have enough fund...:smile:
Thank you and appreciate any inputs..
Cheers
Old Aug 24, 2005 | 05:50 AM
meb's Avatar
meb
If you cannot adjust the camber up front, keep things pretty close to stock.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
minimofo
Sep 9, 2015 10:29 AM
robyb
Aug 8, 2015 06:04 PM
