Scrub Radius
Old Aug 21, 2005 | 06:51 PM
zack_S_moore's Avatar
zack_S_moore
Scrub Radius
Anyone know what the scrub radius value is on the MCS's?
Does a 45mm offset wheel push it from negative to positive?
Same outer diameter tire & stock suspension. Thanks.
Zack
Old Aug 22, 2005 | 11:00 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Zack
Good question to ask Alex@tirerack.com about.
SCRUB RADIUS
Definition: The distance between the extended centerline of the steering axis and the centerline of the tire where the tread contacts the road. If the steering centerline is inboard of the tire centerline, the scrub radius is positive. If the steering centerline is outboard of the tire centerline, the scrub radius is negative. Rear-wheel drive cars and trucks generally have a positive scrub radius while FWD cars usually have zero or a negative scrub radius because they have a higher SAI angle. Using wheels with different offset than stock can alter the scrub radius.
I'd guess that the scrub radius for the MINI is close to zero or slightly negative. With the stock offset at +48mm, an aftermarket wheel with +45mm offset won't likely change the scrub radius to a positive value. See what he says. It might also make a difference which tires (rubber compound) you are using and what road surfaces/conditions you have.
Old Aug 22, 2005 | 11:09 AM
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
....See what he says.
And then make sure you post back here to enlighten the rest of us!
Old Aug 22, 2005 | 11:59 AM
zack_S_moore
10-4.
Old Sep 7, 2005 | 08:19 AM
zack_S_moore
FYI, never got a definitive answer on this. Alex didn't know, either.
Old Sep 8, 2005 | 08:43 AM
Alex@tirerack's Avatar
Alex@tirerack
I thinkmI'd direct it to the mini's engeneering team. Sorry I didn't have an anwser!
Alex
Doc Pain
Mar 10, 2021 04:50 AM
09R56
Oct 12, 2015 09:04 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Nicefeet
Sep 27, 2015 11:14 AM
muddflapp
Sep 20, 2015 03:55 PM
