Interior/Exterior TEFLON or not on senders??
Old Aug 21, 2005 | 08:52 AM
betet's Avatar
betet
Hi all:
I am installing an oil temperature gauge right now. After doing a search online, I am still not satisfied whether to put teflon on the temperature sender or not.
One site mentions that by putting a teflon, you might get false readings because it will not properly ground these senders, such as these links: one two three.... While other sites mention by not putting teflon you might get leaks.. While others mention about just doing a "one layer of Teflon: One
HELP
thanks
///Gilbert
Old Aug 21, 2005 | 10:08 AM
daleCarlsbad's Avatar
daleCarlsbad
According to the last source..... “Ground is normally maintained in the threads of the sending unit. Use only 1 wrap of Teflon tape on sender threads to assure no leaks or loss of ground”.
This says it all. The Teflon will fill-in between the treads, but still allow the “edges” of the threads to make contact. Folks sometimes tend to think "one layer is good......so ten must be better!"
Old Aug 21, 2005 | 10:33 AM
betet's Avatar
betet
Thanks Dale.. It's kinda tuff to get in there so I just want to do it one time.. Different gauge companies also have different thought in either putting teflon or not..
///Gilbert
Old Aug 21, 2005 | 01:04 PM
Battle Cattle's Avatar
Battle Cattle
in my experience with teflon after 1 use it is all cut and has holes in it so I wouldn't worry to much about the ground; just be conservative about it ( DONT USE THE WHOLE ROLL) and you should be ok.
-Josh
Old Aug 21, 2005 | 10:26 PM
betet's Avatar
betet
Thanks Josh.. I guess I won't try to use up a teflon tape roll on each of my senders
I'll just be using one layer and I guess try to monitor if I get false readings..
///Gilbert
Old Aug 22, 2005 | 02:09 AM
BFG9000's Avatar
BFG9000
Extra teflon tape is frequently used to intentionally desensitize knock sensors in domestic cars.
Old Aug 22, 2005 | 05:34 PM
ScottinBend's Avatar
ScottinBend
Why not use the drain plug for the sending unit, a la the official MINI oil temp gauge?
steebo777
How to
33
Oct 10, 2009 08:04 PM
MINICS04
Oct 17, 2008 02:16 AM
miniconcarne
Suspension
Sep 15, 2007 12:35 PM
quikmni
Electrical
Sep 6, 2007 06:10 AM
