Suspension Scrub Radius
Old Aug 20, 2005 | 11:50 AM
zack_S_moore's Avatar
zack_S_moore
Scrub Radius
Anyone know what the stock scrub radius is on the MCS's?
Does a 45mm offset wheel push it from negative to positive?
Same outer diameter tire. Thanks.
Zack
Old Aug 22, 2005 | 05:50 AM
meb's Avatar
meb
Yes, it will be less negative, dunno by how much. But, with a MacPhearson strut, if you dial in more negative camber, the scrub radius becomes more negative; the SAI will intersect the tire's centerline a little higher and therfore meet the ground a bit farther out from the wheel's center line. You don't want zero scrub radius, however.
Doc Pain
Mar 10, 2021 04:50 AM
09R56
Oct 12, 2015 09:04 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Nicefeet
Sep 27, 2015 11:14 AM
muddflapp
Sep 20, 2015 03:55 PM
