Power Steering dead? Need Skilled Advice.
Old Aug 19, 2005 | 02:17 PM
SugarBelly's Avatar
SugarBelly
Thanks for looking, all. :smile:
Driving along at 35mph & suddenly she was quite hard to steer, - obviously no power steering.
MINI Roadside came to get her & the mechanic said she "felt odd, not perfect" when lining her up to load.
Any guess or diagnosis as to what this could be, - caused it &/or whether warranty will cover it since she's under 50K miles?
Thanks in advance!
Old Aug 19, 2005 | 04:05 PM
Eric_Rowland's Avatar
Eric_Rowland
If the PS is really dead, likely the PS fan died, either of natural causes or due to an obstruction, and the lack of cooling burned out the electric motor.
Old Aug 19, 2005 | 04:27 PM
onasled's Avatar
onasled
Very common problem with the Mini S. Pre 03 seems to be the most common victim.
My pump almost burned up the whole car. This will be a warrantee fix if you are still under it. If you do a search here you'll find a very large thread about it.
Old Aug 19, 2005 | 06:03 PM
MadHatter's Avatar
MadHatter
just had my 2005 MCS with 11,000 miles
power steering motor replaced ... so I guess the issue lingers on...
Old Aug 19, 2005 | 06:24 PM
moreorless's Avatar
moreorless
Here's the computer fan screen I put on my '02 MCS just yesterday.......
....Les
Old Aug 19, 2005 | 06:29 PM
g3's Avatar
g3
A couple of months ago I had a seal go out on my 2003 MCS. All the fluid drained out and no power steering after that. The dealer replaced the pump, the seal and the entire rack system under warranty (23,000 miles). Plus, I got to drive a loaner with the JCW package for a few days.
Old Aug 19, 2005 | 06:59 PM
bodinski's Avatar
bodinski
My '03s fan started making a sound like a coffee grinder & was replaced under warranty. Took about 15 minutes & the new fan came with a guard on it.
Old Aug 19, 2005 | 07:03 PM
Jenn B's Avatar
Jenn B
Yep.. it happens and it will be covered.
Mine is being replaced right now.
Old Aug 19, 2005 | 11:04 PM
W3IWI
It happened to my '02 a couple of years ago. Click here to read the NAM archives about my "incident" . It was repaired under warranty and it is still working after another 25k+ miles.
There have been a lot of similar reports. In early '02, the Power Steering pump shared a fuse with the main engine fan, causing much consternation. People have ingested road debris (like platic bags) into the fan and many have added an aftermarket grill over the fan. Personally I use a full skid pan.
UncDeo
Nov 4, 2019 04:08 AM
tylewis
Sep 6, 2015 01:07 PM
Sep 2, 2015 11:15 AM
Suspension Products
Sep 2, 2015 10:32 AM
minipopkart
Aug 13, 2015 05:22 AM
