Drivetrain 19% SC Pulley at the Track
Old Aug 8, 2005 | 02:04 PM
matma92ser's Avatar
matma92ser
I've done a lot of reading here and it seems that the concensus is:
15% = good power and no problems on the street nor track
19% = better power and no problems on the street.... but track?
Those of you with the 19% *and* who also track your Mini, can you add your input? BTW - If I go 19% then I would definitely also do the GIAC and bigger injectors.
Both Webb and Mini-Madness do not recommend the 19% for track use; they both use 15% on their track cars. I have a hard time going against the advice of two tuners that do a lot of track testing and have no vested interest in 15% vs. 19%. Are they correct or are they behind the times?
Thanks for any input!
Old Aug 8, 2005 | 02:19 PM
MINIAACK's Avatar
MINIAACK
There seems to be lot of mixed review with that subject. I personally am running the 19%. Lot of other people are also running the 19% without problems. If you are worried about damaging the motor, you can also run 17% pulley. You can run 15% sc pulley with a 2 % crank pulley. There is a couple of members of NAM that are running the 19% with a 4% crank pulley.
I prefer the 19% for its low end power. At the track I would shift a bit short of redline to play it safe.
Old Aug 8, 2005 | 03:00 PM
onasled's Avatar
onasled
I'm running 18% on the track and since that mod have done about 7 -9 track days. No problems so far, but I'm about to take it back down to 15%. One reason is that I'm being talked out of the lightwieght crank pulley that I'm now using. It's the Alta +3%.
It's really hard to take this step thoutgh as I truely like the power I'm getting from this combo. Not sure what I'll be doing.
Old Aug 8, 2005 | 04:15 PM
marvinthemanic's Avatar
marvinthemanic
Running 19 with Lightweight crank pulley purely for track and no probs. Even in high temps it has no probs (so far...... )
Old Aug 8, 2005 | 05:34 PM
red rage's Avatar
red rage
15% plus 2% crank pulley = FUN No problems, so far
Old Aug 8, 2005 | 07:12 PM
MINIAACK's Avatar
MINIAACK
Why are you taking the light weight crank pulley off? Is ther a problem with running that setup?
Old Aug 8, 2005 | 07:58 PM
onasled's Avatar
onasled
I've had no problems at all, .... but I am pushing the car harder these days and may up the rev limiter. I'm just being told by some that anything over 15% on the track (consistently on the track) will end up screwing up the SC.
Still not sure what I will do at this point. I'm about to go nuts on the motor mods so I need to think this out wisely (which is not something I'm known for)
Old Aug 8, 2005 | 09:43 PM
bgrpph's Avatar
bgrpph
I've had 19 pulley for 18 months and track car 1-2 times monthly w/o any issues- just added injectors/GIAC last month- I do not run more than 20-25 minutes at a time on track. I change my belt routinely- I also try to shift about 6500 PRM-I've had absolutely no issues nor has anyone else here with 19 had issues, except need to replace belt more often.
If i was doing more than just super lap, track days, driving schools- if i was into wheel to wheel racing where much more time spent on track- i'd probably switch to 15 pulley.
Old Aug 8, 2005 | 11:07 PM
marvinthemanic
Sounds exactly like my position
Old Aug 11, 2005 | 01:34 AM
matma92ser's Avatar
matma92ser
Thanks for all the input. I'm still undecided. I keep wavering back and forth on 15% vs. 19%. It seems that some people have had no problems with the 19% on the track, but if it were really that good, why doesn't Webb and Mini-Madness have it on their own cars?
At MMW I did not get a chance to speak with Randy since he was quite busy doing various installs, but I talked to George from Mini-Madness and he seemed quite convinced that the 19% should not be tracked.
Old Aug 11, 2005 | 04:10 AM
onasled's Avatar
onasled
Personally I would never use a 19% "pulley", on the track. It's just too small in diamiter and my concern would be with the belt. That's why I'm using the 15% and +3% crank.
Now I just need to worry about the SC .....
My gusess is that Webb would concure with George.
Old Aug 11, 2005 | 04:43 AM
DrkSilvrMini's Avatar
DrkSilvrMini
i have yet to track my car but i have the 16% M7 on my car and its nice on power. Take it all the way to readline with no problems.
Old Aug 11, 2005 | 08:38 AM
CooperSigma's Avatar
CooperSigma
I'm strongly considering running that same combo, the 15% plus 3% pulley and was wondering how it was on the street?
Old Aug 11, 2005 | 09:22 PM
matma92ser's Avatar
matma92ser
What George told me, and I have read supporting anecdotes from Randy, is that the 19% makes more power in the lower rpm range, making it a great street mod. However, at the higher rpm range (typical track use), the 19% has gone past the adiabatic efficiency of the SC. This results in extra heat rather than extra power. So at high rpm, the 19% makes about the same amount of power as the 15%, but with less reliability in theory because of the extra heat.
I have not had a chance to confirm this by comparing dyno charts of the 15% and 19%. Has anyone done this?
Old Aug 29, 2005 | 11:28 PM
matma92ser's Avatar
matma92ser
Onasled - Any concerns about excessive heat from high RPM supercharger use? Perhaps a 17% SC pulley + 2% crank pulley might be the way to go for track, plus the GIAC and larger injectors...
Old Aug 30, 2005 | 10:14 AM
bouray's Avatar
bouray
...if one went to a 15% + 4% combination, one could go either way fairly easily, not so?
Old Aug 30, 2005 | 05:25 PM
matma92ser's Avatar
matma92ser
My concern is adding too much speed to the accessories (from the 4% crank pulley). Not sure how real of an issue this is though.
Old Aug 30, 2005 | 05:50 PM
SpiderX's Avatar
SpiderX
There are several SC on ebay in the UK for under $200. The shipping is about $130
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
VanisleRyan
Sep 13, 2015 09:55 PM
boydie
Sep 13, 2015 05:06 PM
Emnotek
Sep 11, 2015 04:16 PM
