Drivetrain Alta 15% and Milltek exhaus - get JCW programming or not?
I have the opportunity to have the JCW ECU software put in my car.
Is this worthwhile or no in my car's current state of tune? I will be buying an intake soon as well, though I don't really expect this to affect this question much.
I'm concerned about the JCW tuning expecting the increased fuel flow of the JCW injectors and running lean.
Anyone with any technical knowledge on the subject care to chime in on this one?
Thanks!!!
Thanks!!!
Don't do it, don't do it, don't do it. I'm not sure if it'll do damage or not (run lean) but one guy here did have a similar setup and he LOST tremendous power with the JCW software. The JCW software is very specific for their mods which include a different head (and a 13% pulley and larger injectors). Seriously, one of the MINIs they used for GIAC testing showed the JCW software lost over 10hp compared to stock and more than 20hp compared to the tuned GIAC. And this was for a 15% pulley.
So unless you want to negate the power gained by your pulley, don't do it. The stock software can handle your mods much better.
Originally Posted by markbradford
Interesting - it was billed to me as making cars with similar mods "way faster and smoother"
I wouldn't do it Mark. The JCW software is mapped/designed specifically for the hardware in the kit. Even if your mods are close to the JCW, they are not the same. I'm sure they spent quite a bit of time dialing in the software to work with what's in that kit.
if all that is the case the stock tuning is designed specifically to work with NO MODS ? how can it possibly adapt better ? At least the JCW is mapped for more boost and bigger injectors.
Maybe the car in question is just a freak, mini's tend to vary considerably from one car to the next so who knows. And I am not doubting what anyone saw just curious how stock can possibly adapt better when the jcw is programmed for more out of the boX??
I think the JCW tune is just a very specific tune that takes advantage of the head or something that an intake, exhaust and pulley car doesn't have. It's not like the JCW ECU upgrade didn't work. In fact he THOUGHT it was fast. But the dyno showed a peak power LOSS. There is also the possibility (and probability) that the JCW ECU is a detune for safety. With the extra boost and such maybe the JCW ecu detunes the stock software for added safety.
thats interesting. Maybe it has everything to do with lack of flow from not having the head done.
I see your points about the possibilities of the programing but if they did de tune it they would even get the #'s they do on a stock JCW car.
BTW I believe the jcw pulley is just short of 15% not 13%, slight difference but I thought I would toss that out anyway.
Originally Posted by manoo
i have the jcw tuning with aftermarket mods (15% alta pulley etc.) my car is faster with smoother acceleration compared to the regular tuning.
Originally Posted by dinile
What's the cost of the JCW flash?
I dont know what it would cost, the hard part is finding someone who will do it on a non JCW car.
The dealer also knew that I had an aftermarket cylinder head. That came up during the deliberations.
Last edited by Skiploder; Aug 6, 2005 at 10:45 PM. Reason: because I made a boo-boo!
Originally Posted by Skiploder
The JCW flash also controls the flap on the JCW intake.
The JCW airbox can be fitted to a stock 'S' and no flash is required.
Originally Posted by MINIAC
Not true ... the airbox has its own control unit which is wired into the ECU and opens the flap at 4500 rpm.
I had mine flashed with v42.2 of the Jcw software and the car is running better than ever before. I dont know if its making more power or not but its smooth and linear throught the entire range. Definitly better than the standard software.
greatgro! What's up?
Just one tiny correction; JCW pulley is 14.7%
