P2097 code = ??
Old Aug 2, 2005 | 02:35 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
P2097 code = ??
I have this code, never had it before but what actually can be the cause ? Car runs fine.
This is th eexplanation for th ecode but what exacly does it mean?
Post catalyst fuel trim bank 1 system too rich.
I have made no changes to the car in a while and now I get this code, funny thing is it wont clear out either?
Old Aug 2, 2005 | 02:43 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
You only have one cylinder bank. What scan tool did you use?
Old Aug 2, 2005 | 02:46 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
Its an actron. It show the code and the explanation on the screen.
Old Aug 2, 2005 | 02:52 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
I see what you meant now about 1 bank, I fixed the original post.
Old Aug 2, 2005 | 03:00 PM
andy@ross-tech.com
Ah, I was going to say a scan tool compliant with MINI's should report P2097 as "Post Catalyst Fuel Trim System Too Rich Bank 1"
This means that your rear oxygen sensor (the one after the catalytic convertor) was seeing a fuel mixture that had too little oxygen in it. What mods do you have?
Old Aug 2, 2005 | 03:02 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
head, cam, injectors, some other porting, 15% pulley, 3% crank pulley, alta tmic, header ( w/stock cat ) I am sure tehre are a couple things I overlooked but those are the major ones.
Old Apr 18, 2006 | 07:59 AM
trentf's Avatar
trentf
P2097
Hi,
Did you ever find the problem causing P2097? I just recently threw this code and will not erase.
Thanks!
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
