Intermitant Air conditioning Problems
Old Jul 31, 2005 | 06:17 PM
tomherr's Avatar
tomherr
2002 Mini Cooper, and the A/C works sometimes, and never when you really really need it. I tried the disconnect the battery thing and it works for a few hours. Any other ideas?
Old Aug 11, 2005 | 09:38 PM
1FSTMINI's Avatar
1FSTMINI
cud be alot of things if you didnt fix it yet.......im guessin you might be low on freon which wont let the system turn on cuz ull blow the compressor without the level of freon the system needs to run.
Old Aug 11, 2005 | 09:51 PM
J0kER's Avatar
J0kER
does it not work after runnin' around for awhile or is it more or less at any given moment. like even if the car is cold.
Old Aug 11, 2005 | 10:11 PM
1FSTMINI's Avatar
1FSTMINI
ill say when the car is cold the system might work for alil until it get to hot n the high pressure switch turns the system off.
Old Aug 11, 2005 | 10:21 PM
J0kER's Avatar
J0kER
thats what im thinkin'......
Old Aug 12, 2005 | 06:23 AM
1FSTMINI's Avatar
1FSTMINI
Easy way is to have a friend or your local shop put your car on the machine and do a system check to see how much freon you have in the car and you can go from there with the diagnostic.
Old Aug 12, 2005 | 01:31 PM
LizzyBobio's Avatar
LizzyBobio
Does it go on, then off after a little bit...or just not come on at all?
MiniDan
Sep 3, 2015 04:05 PM
Zettinger
Aug 25, 2015 04:04 PM
polotska
Aug 23, 2015 09:10 AM
Bennyboy
Aug 18, 2015 07:28 AM
