Suspension Do springs with Sway bar?
Old Jul 29, 2005 | 01:18 PM
camelpilot's Avatar
camelpilot
I'm getting a new rear sway bar next month, does anyone know if it's easier to do the rear springs when doing the rear swaybar? Or are the tasks completely independant of each other?
Old Jul 29, 2005 | 02:13 PM
k-huevo's Avatar
k-huevo
When you install the sway bar, you will need to remove the driver’s side rear strut, un-bolt the guide support for the passenger side rear strut and swing that strut towards the rear for clearance. So, although it could consolidate some efforts involved in a spring change, it’s not that much of work saver.
Doing the sway bar separately gives you a little more perspective on the effect of the bar with different spring rates.
Old Jul 29, 2005 | 04:06 PM
kapps's Avatar
kapps
Agreed. It's not hard at all to get the spring/strut assemblies off and when you do it for the swaybar, it'll give you some practice.
Old Jul 29, 2005 | 07:08 PM
whskysouth's Avatar
whskysouth
Do them at the same time...
I jsut had my H-Sport Swaybar and H&R Springs done by Steve McConnell of MetroMotorsports in Atlanta....
Did an awesome job!
If you are going to do this job yourself, make sure you get a pair of spring compressors. Also make sure you mark the alignment of the rear strut assembly pieces.
TooBlue
'02, EB/W, 17" SSR-GT1, Helix 15%, H-Sport Swaybar, H&R Springs
OTW, Alta Blue CAI, Alta Blue Catch Can, Live Wire, Screaming Deamon.
3M Cleargaurd for lights...
Old Jul 29, 2005 | 08:51 PM
kenchan's Avatar
kenchan
I think it should be the other way around.
Do the swaybar with springs.
rtk90
Aug 29, 2019 09:08 AM
ej
Nov 17, 2015 09:21 PM
dropnstylez
Oct 29, 2015 08:57 AM
Suspension Products
Sep 2, 2015 10:32 AM
