Suspension Rear Sway Install Pictorial?
Old Jul 28, 2005 | 07:52 AM
MGear's Avatar
MGear
Just received my Alta 22mm red rear sway bar and anxious to get it installed. I have been looking through previous posts on NAM to see if anyone has posted a pictorial of the install, the written instructions leave a bit to be desired. Can't seem to find any install pictorial, has there ever been one done? If so could you point the way? Also the instructions say to grease the bushings with grease supplied with the Alta sway bar but mine arrived with no grease, what grease should I use and can I get it at my local autmotive supplier? Thanks
Old Jul 28, 2005 | 08:03 AM
webstrands's Avatar
webstrands
Here's Randy Webb's install instructions.
Have fun!
http://www.webbmotorsports.com/forum...topic.php?t=14
Old Jul 28, 2005 | 08:07 AM
MGear's Avatar
MGear
Thanks for the pointer to Randy's pictorial unfortunately when I click on it I get the following message:
"Sorry, but this board is currently unavailable. Please try again later"
Do you think this is just temporary or just not available anymore at all?
Old Jul 28, 2005 | 08:24 AM
webstrands's Avatar
webstrands
I'm sure it's just temporary.
Old Jul 28, 2005 | 08:33 AM
kapps's Avatar
kapps
Click here for minimania's install instructions. I believe it's the same as on Webb's site.
Old Jul 28, 2005 | 08:53 AM
pooch1's Avatar
pooch1
Rear sway bars
Note to above post if doing convertible you will need to remove convertible sub frame stiffener first.Whats required is torx 50 bit.Also on convertible is another frame mount not found on non-convertible.This extra mount is buried under heat sheild for exhaust which requires exhaust removal from rear of car.Add 1hr extra for convertible.Martin.Good Luck
Old Jul 28, 2005 | 10:08 AM
MGear's Avatar
MGear
Yes Pooch1 I am familiar with the convertable scenario but thanks for the heads up. I have a coup!
Thanks Kapps for the second link
Old Jul 28, 2005 | 11:11 AM
kenchan's Avatar
kenchan
www.outmotoring.com has instructions too. :smile:
Old Jul 28, 2005 | 01:58 PM
MGear's Avatar
MGear
Hey thanks everyone as usual NAM members pull through again
W0TM8
Dec 19, 2019 07:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
