Drivetrain Factory limited slip retrofit anyone?
2003 Cooper S, 26000 mi. in for service and have been told they are replacing the flywheel. I would like the limited slip differential and have asked if I could pay for the part and have it put in while car is apart. Has anyone tried to have this done? With what result?
I called another mini dealer and asked if the factory limited slip is available. Was told that dealers don't split the transmissions and the limited slip is only available as part of the transmission. price $3000 exchange.
Anyone have success with a dealer installing any limited slip?
I've tried, and I have an 05 with no LSD (picked my MCS right off the lot w/o checking). I tried asking my local Mini dealer if he could install the LSD, but they quoted me $5K!! I was a bit shocked at that. For the most part, you'd be stuck with Quaife or Ultrik. If you want factory LSD, start looking at salvage.
Good luck.
Good luck.
$3k is a good price for a new '05 transmission. Whether the 1/2 second improvement in 0-60/improved drivability from the wide-ratio box is worth $2k or not is up to you...
I think the Quaife is better than the factory LSD but the '05 gearing is better than the '03. My vote is for salvage '05 (not likely to find one with LSD) plus a Quaife.
Jim
Originally Posted by jimz68
From what I understand, the factory unit is a Quaife. I saw some photos from MINI at my dealer a few months ago showing the LSD unit, and you can read "QUAIFE" right on the unit. Hmmmmm.
Jim
Jim
http://www.motoringfile.com/2004/12/...p_differential
Originally Posted by mikem53
Since the 05 tranny is a Getrag, the factory LSD might not fit the older units... Might want to go with the aftermarket units as suggested above...
Originally Posted by MINIAC
The MINI LSD is manufactured by GKN Driveline ...
Originally Posted by MattMan
I agree with the fact that if you don't race you don't need one.
Originally Posted by rkw
LSD is useful in slippery conditions: ice, snow, rain, loose dirt, etc. In the auto industry, this is the main purpose of LSD (not racing). As an extreme example, consider that you'd really want LSD on your vehicle if you did true off-road driving.
Originally Posted by camelpilot
wth are you talking about? The auto industry evolved from racing.
GKN Factory Info
I'm not going to put in ltd. slip. The additional cost is not justified. Dealer said they would charge 5 hours - $700, to put in an a/m ltd. slip, even with the tranny out of the car due to flywheel replacement. That plus $1200 for the ltd. slip is not good value. Plus the delay in shipping would probably cost me rental charges for the loaner car.
However, were I to order new, ltd. slip would be the first option I'd ask for.
I have autocrossed a little, and accelerating out of the turns really lights up the inside front tire. That is where the ltd slip would help a lot. Also on the street, accelerating out of off-camber turns really sucks too. I don't track the car. Randy on his site says the ltd. slip really gains you very little (on the track) if you drive right. So the cost is not justified. The money would be better spent getting big stick tires (Azeni RT615)
BTW, I heard that there is an improved factory flywheel which will be put in the car. I suspect the flywheel was diagnosed as contributing to excessive driveline play and/or rattle. (my complaints) It would be interesting to know what the exact change was in the flywheel.
Saw the clutch and it has friction material on both sides of it To me it hardly looked worn. I'm very easy on the clutch IMHO. Notwithstanding, I sprung for the $300 clutch and t/o bearing replacement kit since there were no labor charges.
BTW, factory service has them take the tranny out the bottom on the lift, so engine stays in car.
Sep 4, 2015 01:31 PM
Sep 4, 2015 12:51 PM
Tires, Wheels & Brakes
Sep 4, 2015 12:35 PM
Sep 4, 2015 12:34 PM
Okay, just kidding.
