Detailing in the Heat
I am planning going to buy Zaino's Starter package. I live in Phoenix. Does anyone have any comments about detailing in summer heat (right now it's average 110 degrees plus). I do have a garage, but it is still quite warm in the garage, even at night (probably 90+) . Are there any ill effects from waxing in the heat??
If you are using Zaino in the heat, it is even more important to make your coat as thin as possible. My first few coats were too thick and took a lot of Z6 and a stiffer microfiber than I usually use for buffing to get the haze off after the Zaino dried.
You will also have to use more Z6 (quick detail spray) as it will evaporate more on contact and it is important to have enough lube on the surface of the paint when you QD to float any contaminants (dust, dirt, bug guts, etc).
In our Texas dry summers, I've found that I'm using my Oxo Car Duster even more and washing less frequently... A quick dusting every other day when I get home during dry weeks and I'm good for a couple weeks!
My first Zaino coats were done in very similar heat as we have here today. It was 2 years ago almost to the day.
https://www.northamericanmotoring.co...ad.php?t=12195
The only problem I had was keeping the clay from sticking everywhere
molala
Oct 2, 2015 01:53 PM
