HELP! Power steering going out
Old Jul 10, 2005 | 08:04 AM
kalbone's Avatar
kalbone
My power steering has been going out and coming back on for a while now. What would cause it to go out? I dont auto cross or road race. It really sux not having power steering when you need it. can someone help me?? thanx
kalvin
Old Jul 10, 2005 | 08:06 AM
mdsbrain's Avatar
mdsbrain
Is your car out of warranty yet? If not I would say take it by the dealer. That is if the drive isn't to far.
Old Jul 10, 2005 | 11:15 AM
hyobum's Avatar
hyobum
Check your hydraulic fluid. That exact problem happened to me once. I had to buy hydraulic fluid from a porsche dealer because bmw uses a special type of hydraulic fluid called CHF 11S, used by only a few car manufacturers. If your hydraulic fluid tank is empty, fill it up and then take it to the dealer. In my case there was an internal leak so I coudn't see any leak on the ground but the fluid was definately going somewhere. In the end, my dealer switched the entire steering mechanism (or whatever you call it) under warranty.
Old Jul 10, 2005 | 12:51 PM
Elmann's Avatar
Elmann
If my information is correct the Mini uses an electric motor for the power steering instead of the belt driven pump on many other vehicles. If this is incorrect someone please set the record straight. If it is an electric motor that drives the unit you may have a problem in the electrical rather than a fluid problem.
Good luck!
Old Jul 10, 2005 | 12:59 PM
lotsie's Avatar
lotsie
Good luck!
Yup it's an electric pump. Thats the whirring noise you hear while sitting still and turning the wheel:smile:
Old Jul 10, 2005 | 01:55 PM
kalbone's Avatar
kalbone
yeah it's out of warranty. however i took it to the dealer when i had 49,500 miles. i told them that the power steering would go out on me. so i went with the tech and drove around, but nothing happened. they told me that i couldn't prove to them that it was working. so he told to just drive around and see if it does it again. It just happened to be the weekend bfore AMVIV. after AMVIV i was out of warranty. just my luck.
thanks everyone for replying
Old Jul 10, 2005 | 03:40 PM
mikem53's Avatar
mikem53
If you have a record of seeing the dealer for this problem before the warranty expired, then they should honor it. You were correct and just because they could not reproduce the problem, doesn't mean it didn't exist when it was under warranty...
It's worth a try...
mike
Supertractor3
Apr 7, 2017 11:16 AM
molala
Oct 2, 2015 01:53 PM
ou812_tugger
Sep 5, 2015 03:24 PM
Ntety
Sep 2, 2015 08:39 PM
Suspension Products
Sep 2, 2015 10:32 AM
