Drivetrain What is your max. psi of boost?, and what you have to get it?
Old Jul 4, 2005 | 07:48 AM
MCSPR's Avatar
MCSPR
What is the max. amount of boost that you reach (in psi) and what do you have to get it?
Old Jul 4, 2005 | 07:53 AM
Poderes1's Avatar
Poderes1
I'd like to give you an answer as far as my MCS is concern but I still haven't been able to get my boost/vac gauge connected right so its only giving vacuum reading. But i can tell you this, with the Alta Intake and 17% pulley, I feel that i am getting awesome gains. Sorry i can't give you exact numbers.
Old Jul 4, 2005 | 08:08 AM
MSFITOY's Avatar
MSFITOY
16 psi with 15% pully:smile:
Old Jul 4, 2005 | 08:12 AM
MyPocketRocket's Avatar
MyPocketRocket
16psi with 15% as well
Old Jul 4, 2005 | 08:14 AM
SpiderX's Avatar
SpiderX
I get 16 with a 19% and large IC
Old Jul 4, 2005 | 08:15 AM
mikem53's Avatar
mikem53
What was stock boost? Around 12psi... Thanks
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
15-16psi with 15% Alta pulley.
Old Jul 4, 2005 | 08:18 AM
MCSPR's Avatar
MCSPR
Did you have the same boost with a 19%?....If you have a 19% you gone a get more boost than a 15% pulley i think or not???
Old Jul 4, 2005 | 08:31 AM
MyPocketRocket
I did not know how much I had for a stock pulley. I added 15%, large IC and boost gauge then I got 16 psi at 5500 rpm in 2nd gear.
I'm thinking to add the lightweight crank pulley...shall I see 18psi?
Old Jul 4, 2005 | 08:43 AM
MSFITOY's Avatar
MSFITOY
I think 11psi is stock...didn't have a gauge at the time.
Maximusmini's Avatar
Maximusmini
I have 22 with my twincharger...
Old Jul 4, 2005 | 08:46 AM
MSFITOY's Avatar
MSFITOY
Ya better install a boost gauge real soon Zak and keep a close eye on that bad boy :smile:
Old Jul 4, 2005 | 09:18 AM
trickedmotoring's Avatar
trickedmotoring
i have read that stock boost is around 9 to 10.
Old Jul 4, 2005 | 09:32 AM
spillman's Avatar
spillman
I have seen around 19 psi. I have the 19% supercharger pulley with the 4% crank pulley and larger intercooler.
Old Jul 4, 2005 | 09:55 AM
Bahamabart's Avatar
Bahamabart
The stock car is 10.5lbs if not mistaken, I was told that a 15% pulley takes the boost to 14.5lbs.
Then there are 16%, 17% and 19% pulleys - the vendor should be able to confirm actual boost as oppose to guage boost.
There are formulas for this stuff and the pros on the board can set the numbers straight - don't rely on people's guage reads for there are alot of crappy guages out there.
Old Jul 4, 2005 | 09:56 AM
glassintrepid's Avatar
glassintrepid
Mine is at 15 psi. I have intake, 15% pulley, exhaust, MTH. Something wrong? Im at sea level too.
Old Jul 4, 2005 | 09:59 AM
MCSPR's Avatar
MCSPR
Crappy gauges??....
Old Jul 4, 2005 | 11:07 AM
Maximusmini
All in due time Sid right now is maintenance time..
Old Jul 4, 2005 | 11:12 AM
MCSPR's Avatar
MCSPR
How sells them???....any website?
Old Jul 4, 2005 | 11:14 AM
MCSPR's Avatar
MCSPR
How sells them?...any website?
Old Jul 4, 2005 | 11:53 AM
aokdoug's Avatar
aokdoug
was @17# with 19% gaic miltek header&cat-back.
that was back in march around 75 degrees @sea level.
now-92 degrees, light crank plulley,larger intercooler running 15#.
does that sound right?
guages- i have stewart warner boost 25# max, volt, water,
oil temp,oil pressure, gus shift-lite. colors match perfect.
looks very retro. put the oil temp.&water temp. in the center vents.
doug
Old Jul 4, 2005 | 09:16 PM
BluMiniMe's Avatar
BluMiniMe
18lbs w/19% pulley & GRS IC... and a new belt. After a couple thousand miles, I start getting a little belt slip and that number goes down to about 17%.
Old Jul 5, 2005 | 05:18 AM
Detonics's Avatar
Detonics
Do you guys get 15psi with JUST the Pulley alone without CAi, remap and etc? I got 16psi with 15%,Cai, and remap... Is my boost still low?
Old Jul 5, 2005 | 11:27 AM
ATSTodd's Avatar
ATSTodd
My wifes car got 13.5 psi @7200 rpm with a 15% pulley and MTH. On my JCW car with MTH I got 12.75 psi @ 7200 rpm with the same gage. Boost sourced from the fuel pressure regulator nipple on the intake manifold. Ambient temp 89F. 2nd gear for both.
My apexi AFC read 1.08 kg/m on the peak hold but has read higher at 1.12 before. Maybe the SC wasn't fully warmed up and sealing properly.
It would be nice if you could list the conditions you took your readings under. Ambient temp can have an effect on the reading.
Todd
Old Jul 5, 2005 | 01:14 PM
ALTA2's Avatar
ALTA2
Manufacturer
Todd brings up a point here. The ONLY way to compare boost is using what boost you are getting at WHAT RPM. If one guy has a 15% and a stock redline and another guy has a 15% with a 7600 redline, there will be differeces in boost seen.
