Marketplace - Archive Old Marketplace threads and posts (Read-only). Please use appropriate Marketplace forum for new posts.
FS: Leda Coilovers
Old Jun 25, 2005 | 07:02 PM
k-huevo's Avatar
k-huevo
FS: Leda Coilovers/SOLD
Leda sport model coilovers for $1050 shipped in the U.S. The fronts come with 250 lb. barrel springs designed by Leda for the MINI, spring hats & shaft nuts and cut down bump stops that will accommodate the stock dust boots. The rears come with 275 lb. Hypercoil springs, bump stops, spring hats, Leda dust boots and the stock MCS guide supports attached. The package also includes suspension wrenches and an extra set of 350 lb. Hypercoil springs for the rears. There is a caveat in that one of the rear shocks has a sheared allen key in the shaft slot. All shocks have been rebuilt and have only 200 miles on them since.
Old Jun 25, 2005 | 08:31 PM
OasisT's Avatar
OasisT
PM sent
Old Jun 28, 2005 | 05:00 PM
k-huevo's Avatar
k-huevo
Here are answers to some questions I’m receiving about the Ledas. The allen slot is for holding the shaft while turning the top nut. The work around for the shaft with stuck key is an impact wrench.
There are some minor rust spots on the rear shocks; however, the condition of the working parts is excellent. The value of the recent rebuilds is over $350 plus a $65 front shaft replacement and means they are functionally like new.
The extra Hypercoil spring set has a retail value of $150. The 350 lb. rate would benefit those wanting added turn-in. I found the stiffer springs a bit much for street use.
The front barrel springs have an advantage over conventional wound springs in that they can compress further (increased travel) without binding, a plus with extreme lowering.
The ***** on the Sport Model Ledas are very easy to reach and with 24 positions a setting can be found for almost every situation.
http://www.racersedge-inc.com/struts.html
Old Jul 8, 2005 | 12:45 PM
k-huevo's Avatar
k-huevo
Here is a picture of the coilovers. The front guide supports are not included.
Old Jul 8, 2005 | 01:30 PM
onasled's Avatar
onasled
... do the flip-flops come with this deal? If so, I might be interested!
Old Jul 8, 2005 | 01:55 PM
newbs49's Avatar
newbs49
Onasled
If your interested in his. I'm interested in your setup. You better check how they are setup,might not meet your needs. How's the club racer coming.
Old Jul 8, 2005 | 04:11 PM
onasled's Avatar
onasled
....... just wanted the Flip-Flops, not really after the Ledas ....
Old Jul 9, 2005 | 08:06 AM
newbs49's Avatar
newbs49
onasled
I have a nicer pair of flips for ya. Race proven. Heard from our buddy in Denver lately. Still waiting for a reply on his new and improved site. I guess he finally got his Lotus. Have fun at the Glen and good luck.
Old Jul 10, 2005 | 08:01 AM
Dr Obnxs's Avatar
Dr Obnxs
I just put some of these on....
and they will take longer to set up (height, dampening), but even setting them at the same height as the H-Sport springs it's an improvement.....
Good deal on the struts....
Matt
Old Aug 5, 2005 | 06:52 PM
k-huevo's Avatar
k-huevo
Just in case some of you missed these.
RIchard Nguyen
Sep 14, 2016 11:43 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
sssevita
Mar 20, 2016 06:24 AM
CooperSharp
Oct 12, 2015 09:21 AM
gnhovis
Sep 28, 2015 10:56 AM
