Chips- Terrified of sandpaper
Old Jun 19, 2005 | 02:26 PM
CARdiac's Avatar
CARdiac
I have never been good at stone chip repair and after a recent road trip I am in need…. I even have a chip on the leading edge of my black roof.
I bought Touch-Up Paint Applicators from Griot’s Garage but need any advice you can give me. I bought the Official Mini touchup paint… it comes with color and a clearcoat… I searched a couple of sites and I am terrified of using sandpaper on my black roof…. Please give me any advice you can offer…. How do I make it look the best with the color and clearcoat?
Old Jun 19, 2005 | 03:17 PM
Goose's Avatar
Goose
I sympathize with your plight... paint chips are the worst.
I also have the Griot's paint applicators, and have had somewhat mixed results. Depending on the size of the chip(s), you may just be better off with some very small (#0000 or so) artist's brushes.
Another product that I've considered but have not gotten is Langka. It sure looks like polishing compound, but alot of people swear by it.
Hope this helps...
Old Jun 19, 2005 | 03:27 PM
gokartride's Avatar
gokartride
I've yet to get satisfactory results from Langka (their web site shows a child doing it....yeah, my egos bruised). Apparently Lankga has "issues" both with metallic paint AND w/ clearcoat.....ouch!!
A local body shop fixed one spot on my MINI by using touch-up paint and then polishing the snot out of it!! Best I've seen so far.
I think I'm going to bump it up another notch and go professional one of these days to fix the few chips I currently have. Need to research this.
Old Jun 19, 2005 | 04:41 PM
911Fan's Avatar
911Fan
I've used Langka and have been satisfied with the results. The trick with metallics is to use the minimum amount of paint. If you attempt to fill the chip with metallic, it will become too dark compared to the surrounding area. One light layer of metallic followed by however many layers of clear it takes to fill (actually over-fill) the chip will avoid that problem.
As to the earlier comment about Langka being polishing compound -- I think it chemically dissolves the not-fully-cured touch up paint as opposed to acting like an abrasive.
Old Jun 20, 2005 | 03:12 PM
agranger's Avatar
agranger
Langka is good on Chips, barely adequate on deep scratches of any length.If you want a great applicator, search the Langka site for their little red toothpick things with foam tips. Very cool!
Old Jun 20, 2005 | 08:37 PM
C4's Avatar
C4
Fix the chips and do yourself and your car a favor and invest in a clearbra kit:
www.accuguard.biz
Old Jun 21, 2005 | 06:59 AM
CARdiac's Avatar
CARdiac
www.accuguard.biz
Stone bounced off my headlight (protected by the same product as clearbra) and hit my roof.
Old Jun 21, 2005 | 07:44 AM
C4's Avatar
C4
My clearbra kit includes the leading roof edge piece as well. Fixing paint chips in the MINI is an uphill battle because the beautiful paint job is fragile (water based) and can't stand the rigors of highway driving. Since constantly fixing rock chips or respraying the bonnet every 2 years are not feasible options for me, I opted for the best solution possible and that was my Venture Shield clearbra.
I highly recommend it. It is nice to be able to do roadtrips and not having to worry about your paint getting sandblasted by road stones and pesky bugs
Old Jun 21, 2005 | 01:14 PM
CARdiac's Avatar
CARdiac
C4, do you have any pictures?
Old Jun 23, 2005 | 01:30 PM
C4's Avatar
C4
Yes, but honestly you won't be able to see the clearbra much at all, because the material is nearly 99.9% optically clear.
Old Jun 23, 2005 | 01:33 PM
CARdiac's Avatar
CARdiac
I am interested in the point where the bra ends... how does that look?
Old Jun 23, 2005 | 03:16 PM
Goose's Avatar
Goose
Where the bra ends depends on the supplier. Different companies have slightly different approaches to cutting the patterns. Most usually end just above the headlights/hood scoop.
I think there are only two companies actually producing the material -- 3M is the big guy and somebody else that I can't remember. Both are fine; the unknown guy supposedly had a "clearer" film, but 3M has countered this with an improved film - take your pick. Having seen the OEM film at my dealer, it looks a little thinner than the standard 8 mil thickness (although I can't be sure).
Loads of companies sell the two films under various brand names - take your pick. Prices range over a pretty wide amount, with big differences in product support/warranties. With a MINI, you're better off hiring a pro to install the film due to the compound curves of the hood. Find a local outfit that's been doing clear bra installs for a while, preferably with experience with MINI's. Given the complexity of the install, a pro's gonna charge you $500 to $750 for a full-front install.
Old Jun 26, 2005 | 07:08 PM
911Fan's Avatar
911Fan
imo, there are several problems with the "Saran wrapped" approach...
The biggest is the unsightly edge which collects dirt and wax. The paint color makes this a lesser or greater issue.
Second, every plastic wrapped car I've seen has had very light scratches on the plastic. Sure, the paint might have ended up with the same very light scratches. But you can deal with very light scratches on the paint. You can't do anything when the plastic gets scratched except replace it.
Finally, there is the visual difference between the painted surface and any adjoining plastic coated surface, especially from certain angles. Maybe if the entire surface was covered, without any demarcation line, this would be less objectionable.
I prefer the more "organic" touch up paint + Langka approach. Besides, a few driving related paint chips aren't such a bad thing -- they're just proof of enjoyment!
Old Jun 27, 2005 | 07:09 AM
CARdiac's Avatar
CARdiac
Thank you... I first saw the clear bra at a car show, when it shoudl be looking its best and I felt similar... they also used it on a white car which should have hidden the line well.... ahhh the struggles of paint chips... I will keep working on my Deflector Array ... and no I am not a Treckie...
Old Jun 27, 2005 | 07:10 AM
CARdiac's Avatar
CARdiac
I have my touch-up, Griots Brushes and the Lanka... I will practice on my Camaro first and see how it goes... I just need to wait until the outside temp gets below 95... may have to wait a couple of months.
Old Jun 27, 2005 | 08:56 AM
C4's Avatar
C4
The second generation VentureShield clearbra film is superior to 3M's in durability, strenght and optical clarity. Whereas in the 3M films I have seen you can spot the "line" where the bra ends, it is much harder to see it in the VentureShield film. The VentureShield product has a lifetime warranty vs the 5 year warranty offered on 3M films. I am glad I went with the VentureShield product
Old Jun 27, 2005 | 09:00 AM
C4's Avatar
C4
I really feel sorry for your car because the touchup paint/Langka approach yields to a very, shall we say, rundown look. If you like to spend your life filling up paint chips and wearing down your clearcoat with the offensively smelly Langka, hey be my guest!
I personally got sick and tired of the "organic" look.
I hate paint chips and so far my clearbra is providing 100% protection, not to mention a clean nearly invisible look
Old Jun 27, 2005 | 09:02 AM
C4's Avatar
C4
Ypu'll soon get very frustrated fixing paint chips, specially on a car with metallic paint
I much prefer the "line" on the bonnet than the sight of chipped paint. If you have the time and money to fill paintchips, hey its your car....
Old Jun 27, 2005 | 09:13 AM
C4's Avatar
C4
Here is my '05 MCS bonnet with the VentureShield Clearbra kit:
(www.accuguard.biz)
Line? What line?
Old Jun 27, 2005 | 09:19 AM
C4's Avatar
C4
I paid $325 for my full VentureShield MCS clearbra kit.
The kit consists of the following pieces:
*Leading Edge of roof
*Bonnet
*Hood scoop
*Front bumper
*Top of front bumper
*Exterior mirror caps
*Headlights
*Front marker lights
*Front fog lights
*Upper and lower chrome grille slats
*Front door handle cups
Lifetime warranty against yellowing, peeling and discoloration. (3M can't match that).
The car looks fantastic. No more worries about paint chips and nauseating Langka on the protected areas.
-=gRaY rAvEn=-
How to
44
Jul 17, 2014 02:35 PM
dwebber18
Tires, Wheels, & Brakes
Jun 3, 2009 05:43 AM
