R50/53 Fan making noise???
Old Jun 13, 2005 | 06:38 AM
AWMCS's Avatar
AWMCS
Fan making noise???
Is it normal for my 2005 MCS, when stationary, to have the fan kick on every 10 to 15 seconds then stay on for about 20 to 30 seconds, shut down and then start over again? I do live in Hot and Muggy Central Florida and that may have something to do with it since when I turn the A/C off the fan does not kick on? Any of you have the same, it does seem to make a lot of noise.
Thank you,
Andreas
Old Jun 13, 2005 | 06:42 AM
kapps's Avatar
kapps
Yea, the fan is loud and moves a lot of air. It has two speeds. When you turn the A/C on, it will almost always run on low speed. Once the coolant reaches a set temp (I believe 212) it will kick over to high. I'm not sure about it kicking in and out every 20 seconds, mine will stay on until I get moving again.
Old Jun 13, 2005 | 06:46 AM
AWMCS's Avatar
AWMCS
Thank you, seems to be normal then. It is pretty loud though. I figured everything else was fine since the chrono package shows normal temp, oil temp and oil pressure.
Andreas
Finhead
105
Aug 14, 2023 07:51 AM
rikaro
Aug 7, 2021 02:33 PM
theblackfalcon
Oct 11, 2015 09:49 AM
damncajun
Aug 17, 2015 08:25 PM
Fizzyx
Aug 14, 2015 08:24 PM
