Got a jack today- question about raising my MINI....
Old Jun 5, 2005 | 07:23 PM
jbsf3's Avatar
jbsf3
Hello all. I went to Harbor Freight today (decent stuff for cheap, www.harborfreight.com) and picked up an aluminum "racing" jack and two jack stands. I used them today to remove the rear fender wheel wells to install my clear fender reflectors- worked out great. I also got the jack/stands so I could do my own tire rotations. My question is - where is a good jack up location in the middle of the vehicle so I can get one side totally off the ground to perform the tire rotation? Am I missing something or is that how it is done? This sure beats using the factory jack! Any suggestions are appreciated, thanks.
Old Jun 5, 2005 | 07:44 PM
kapps's Avatar
kapps
What most people do is raise the MINI from the metal frame behind the front jacking point and use a jackstand under the actual jacking point. Raising the front will bring both wheels on that side of the car off the ground.
Old Jun 5, 2005 | 07:47 PM
jbsf3's Avatar
jbsf3
Sounds good- I'll give it a try, thanks for the quick respone
Old Jun 6, 2005 | 05:48 AM
Koopah's Avatar
Koopah
jbsf3 --
Go HERE for some good information and pictures on how to safely jack-up the MINI.
Theo
Old Jun 6, 2005 | 06:35 AM
Jdewey's Avatar
Jdewey
raising Mini
I just put my floor jack under the front jacking point, not the metal plate.
Works fine, gets both wheels on one side off the ground.
John
Old Aug 12, 2005 | 11:07 AM
blalor's Avatar
blalor
You got the jack stands from HF? Those look really nice (and small), but they don't seem to have them on their site today.
Old Aug 12, 2005 | 06:16 PM
kenchan's Avatar
kenchan
on this car you can jack up the front factory jack point and the
rear will lift up as well.
I use 2 hydraulics to do rotations. as far as using your jack stands,
as mentioned above, just set the hydraulic under the black plastic
molding about 5-6 inches towards the middle of the car and about
a foot from the front factory jack point and up you go.
then place your jackstand on the factory jack points.
hope you got some wheel choks.
Old Aug 13, 2005 | 06:41 AM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
For frequent jacking I suggest taking off the stupid rubber jack points and using the place where they were to jack the car. I had my Mini on a jack to change to race wheels and the #&*@'ing thing came off (I've probably hit a few too many cones with it autocrossing) and the car fell onto the jack right over the passenger-side footpan. I now have a nice hump in the floor there. I'm sure it will pound out but it still makes me angry to think about it.
surfblue
Oct 24, 2018 01:20 AM
Inziladun
Sep 3, 2015 10:35 AM
thebordella
Aug 31, 2015 01:37 PM
ShadyCoop
Aug 24, 2015 06:05 AM
