R50/53 Massive Oversteer
Old Jun 3, 2005 | 12:10 PM
british kompressor's Avatar
british kompressor
Massive Oversteer
hi,
I have a 2005 MCS that I got about 3-4 weeks ago, it has about 1000 miles on it as of today.
I was having fun on the highway, and when I took the offramp, the rear en came out pretty fast . The best way I can describe it is how the 1980's porsche 911's handled. This was under moderate braking, so my porsche reflexes kicked in and I taped the throttle and just like a 911 everything came back in order. what's weird is while the car was sliding smoothly sideways, there was never even a little tire squeel .
Now, this was on a pretty hot day (90+), and I noticed that the tires had ALOT less grip when the temperatures are high. They seem to be at their best in the 65 - 75 degree range.
has anyone expericanced this with the stock runflats (Dunlop 5000's) ?
Old Jun 3, 2005 | 12:14 PM
british kompressor
sorry for the typos, i'm at work and have to type really fast.
Old Jun 3, 2005 | 12:19 PM
JCW Driver's Avatar
JCW Driver
Were you braking when the rear end began to give?
Old Jun 3, 2005 | 12:59 PM
british kompressor
I was starting to brake but very moderatly. When I entered the curve, I had to slow down about 15MPH so it wasn't hard braking.
Have you had this happen to you?
Old Jun 3, 2005 | 02:37 PM
flyboy2160's Avatar
flyboy2160
deleted
Old Jun 3, 2005 | 02:57 PM
MSFITOY's Avatar
MSFITOY
Wow...you must've been flyn Did you have the DSC turn off? Mine will rotate at will with throttle lift at those speeds
Old Jun 3, 2005 | 04:00 PM
SoCalSam's Avatar
SoCalSam
Must have been some special conditions to get a front-wheel drive car, un-modded (?), to get massive amounts of oversteer. I've thrown the back end out some but that was on a 90 degree turn I took at speed.
So how fast and such were you going?
Old Jun 3, 2005 | 05:51 PM
mikem53's Avatar
mikem53
So what is considered normal behavior for these cars. Say on a clover leaf getting onto a highway. If I take this at a good speed, should I expect to slide on all corners, or is the rear going to hang out. Maybe the front will plow?
I just couldn't get the total feel during my test drives....
Old Jun 3, 2005 | 09:13 PM
british kompressor
For everyone's information, the car has no modifications.
Here is more detailed information:
going straight at about 70 and entering a clover leaf at about 60, it seems like the braking that is applied just by the fact that the car is turning will take enough weight off the rear wheels to break the rear end loose.
What is really interesting, is the fact that this will only happen when it's really hot out. When it's colder ~60-70) the car feels alot more neutral in handling.
anyone had this before?
Old Jun 3, 2005 | 09:14 PM
british kompressor
why did someone post:
"deleted"
Old Jun 3, 2005 | 09:57 PM
1nf3rn0's Avatar
1nf3rn0
It might be a combination of odd onramp conditions mixed with the rigidity of the runflat tires (i think i read you have them...). I recomend you use your runflats up and then move on to some nice nonrunflat tires. They offer much better controll.
Old Jun 3, 2005 | 10:13 PM
Johnny L's Avatar
Johnny L
Hey, Brittish Kompressor--you're giving me too many ideas. Shame on you!
Old Jun 3, 2005 | 11:03 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
"deleted"
This was a post done in error. I can remove it altogether if you wish.
Back to the oversteer. Two thoughts-
One: the road conditions- maybe it was due to something affecting traction at that point in the road- some slick fluid on the road that could not easily be seen and avoided. OR
Lift-Throttle Oversteer A handling characteristic that causes the rear tires to lose some of their cornering grip when the throttle is released during hard cornering.
http://www.autozine.org/technical_sc...handling_5.htm
See Lift Off oversteer
http://www.rassoc.com/gregr/weblog/a....aspx?post=601
Last paragraph.
Old Jun 3, 2005 | 11:50 PM
XAlfa's Avatar
XAlfa
I've never come close to "massive oversteer" with stock suspension and runflats. It seems like this could happen if you had the power on pretty hard coming into the turn, then abruptly lifted off the throttle and applied some brake pressure at the same time. Never tried that myself, and don't think I ever will...
Old Jun 4, 2005 | 12:22 AM
Samtrak's Avatar
Samtrak
oversteer is much more fun than understeer in my book.
thankgoodness these babys can pull right out of just about anything
its not quite drifting style, but the all whell slide is in effect.
with a crazy suspension and weight reduction in the back, over and under steer are easily controlled or exploited; your choice.:smile:
Old Jun 4, 2005 | 05:19 AM
kenchan's Avatar
kenchan
What was your tire pressure?
Old Jun 4, 2005 | 06:14 AM
Philpug's Avatar
Philpug
Sounds like there was somehting on the road that caused it.
Old Jun 4, 2005 | 07:46 AM
british kompressor
I have no idea what the tire pressure was, I got the car only 3 weeks ago so it's whatever they set it to.
Just so everyone is clear, I'm not complaining of this behaviour , I MUCH rather oversteer then understeer. The reason for my first post was that It was so unexpected that I thaught maybe somehting was wrong with the car.
Now that I think of it, with the MINI's weight balance, it's quite normal that the end comes loose under mild braking in a hard curve.
I went out to try it again today, and all I can say is WOW. I could "powerslide" almost all the way through a bend as if it was a 911... That's just amaizing!!!
I wish I never found that out, now the poor runflats are going to last all of 6 months
Old Jun 4, 2005 | 08:45 AM
Pamlico's Avatar
Pamlico
You might want to check those pressures. It's not uncommon for things to be off by quite a bit.
Old Jun 4, 2005 | 11:46 AM
buzzy's Avatar
buzzy
Mine was delivered with 27psi all round. You might want to check yours.
Luke
Old Jun 4, 2005 | 11:57 AM
brgfan's Avatar
brgfan
The stock all-season run flats, aren't the best tires for corners, but they should make a lot of noise before they let go. The only exception being if you break in a corner hard enought to lighten the rear end and have it start to come around on you. (Under this circumstance you'll probably also feel the anti-locks start to pulse on the rear wheels when the rear end gets loose.) Break before the corner, and then on the gas. The car should be pretty neutral with stock suspension.
Check out: http://www.se-r.net/car_info/suspens...cle%20Dynamics
BTW, be careful on the public roads. Entrance and exit ramps can have nasty surprises, like oil, gravel, debris, etc. If you really want to see what you car's limits are, do a day at the track, or check out a local performance driving school. You'll have a ball!
Old Jun 5, 2005 | 02:23 PM
MINI Monkey's Avatar
MINI Monkey
I would guess their was something on the road. Brgfan is right, the runflats make all kinds of noise when you take them to the limit. I have been autocrossing on mine and they are terrible. I haven't experienced much oversteer on them though. I want a rear sway bar to counter the understeer. I can't wait to replace runflats.
carid
Dec 28, 2025 04:11 AM
patsum
26
May 29, 2021 06:29 PM
minimofo
Sep 20, 2015 05:17 PM
LeftyS7
19
Mar 13, 2005 06:16 PM
flyboy2160
Suspension
16
Oct 7, 2004 07:43 AM
