Drivetrain Help with DTC
Old May 15, 2005 | 01:36 PM
spillman's Avatar
spillman
Help with DTC
My car chip is reading a "unkown powertrain dtc." Trouble code number is P2270. Does anyone have any idea what this trouble code is?
Old May 15, 2005 | 01:59 PM
ScottinBend's Avatar
ScottinBend
Here is a link to the codes http://www.obdii.com/codes.htmlThe code doesn't conform to the numbering system. The first digit should be a 0 or a 1. Probably need to check with the dealer.
Old May 15, 2005 | 02:05 PM
spillman's Avatar
spillman
This is what the Car Chip is saying. Guess I'll be calling up the dealer Monday.
Problem 12 5/15/2005 3:17 PM MINI P2270 Unknown Powertrain DTC (SAE Controlled; Fuel and Air Metering and Auxiliary Emission Controls)
Old May 15, 2005 | 02:30 PM
Cooper S IRE's Avatar
Cooper S IRE
the code is "o2 sensor signal stuck lean bank 1 sensor 2"
hope this helps
Old May 15, 2005 | 02:47 PM
spillman's Avatar
spillman
hope this helps
Hmmm.... That makes sense. I just installed the Mini-Madness Post cat signal converter. Have been having problems with it sense I installed it.
Thanks for the help guys!
Old May 16, 2005 | 02:27 PM
ScottinBend
hope this helps
Where did you find this info?
Old May 17, 2005 | 12:13 AM
Cooper S IRE
in the back of the Bentley MINI Maintenance manual
its a great book everything you need to know
Old May 17, 2005 | 07:24 PM
ScottinBend
Excellent.....thank you sir. Didn't even see them there.
Old May 18, 2005 | 01:00 PM
Cooper S IRE
no problem glad to help
blantonator
Oct 2, 2009 04:43 PM
Jerome81
Jul 30, 2008 11:10 PM
Blitzkrieg.
Jul 29, 2008 10:08 PM
fronesis47
Factory JCW Talk (2009+)
Jul 27, 2008 10:44 AM
gizzer777
Apr 14, 2007 02:04 AM
