Optional mounting position for engine ground wire?
Old May 6, 2005 | 06:58 AM
MyPocketRocket's Avatar
MyPocketRocket
I'm ***-ed
I broke the factory ground wire mounting.(in red circle) Does anyone know what could be the option for mounting the ground wire? How about the one in yellow arrow?
Old May 6, 2005 | 07:26 AM
rataha's Avatar
rataha
How about to the left of the red circle on the Motor mount??? Sorry I am not home now so can't look real cllose. How did you break the existing one? can ou have it welded back on????
Good luck I hate broken MINI's
Originally Posted by MyPocketRocket
I'm ***-ed
Old May 6, 2005 | 07:40 AM
MyPocketRocket
That's what I'm thinking. thanks!
Old May 6, 2005 | 04:28 PM
obehave's Avatar
obehave
My 2¢ but I think you'd be better not using that. It's a structural support location. Not the ideal spot for a ground wire.
You can safely use any non support location maybe even one of the IC standoff towers. Not much weight or stress on them.
Old May 6, 2005 | 06:11 PM
onasled's Avatar
onasled
If your arrow is pointing to one of the IC clamps, then you can't ground anything there because they are insolated from the motor via the rubber boots they are holding on. You'ed be better off going to the motor mount as I think rataha suggested.
Old May 6, 2005 | 07:03 PM
Petrich's Avatar
Petrich
Rocket,
Not sure what you can and should do about your repair.
The grounds in a modern car are carefully chosen by the design enginers to minimize Electromagnetic Interference (EMI) to the operation of the complex digital circuitry that controls the car. There is a lot to be said here. Look at the ground busses in the rear trunk area and under the seats. That particular heavy bus wire may carry the large currents for the battery, starter, and other accessories and also the much smaller noise currents picked up from the various sensors and those generated by the digital systems. A disruption of those noise circuits could (not "will") create unwanted problems.
I am an experimentor and do-it-yourselfer, and even I would make every effort to repair or replace the damaged ground as close to stock as possible.
Regards,
John Petrich in Seattle
Old May 6, 2005 | 07:20 PM
MyPocketRocket
Well thanks for the good info. I think what I did now as you see in the picture, I did use the JB weld and tighten both top and bottom real tight. Now it looks like it really well attached.
I will try call BMW to see if they would replace it for me under warrantee.
Heck...no more fooling around under the bonnet for me then.
Old May 6, 2005 | 07:26 PM
bodinski's Avatar
bodinski
I too agree with Rat. You could probably still use the factory wire there, too.
Best - Bodinski
Old May 6, 2005 | 09:45 PM
Daktaklakpak's Avatar
Daktaklakpak
I was in the same boat as you are. I gave the bolt a little to much oomph and broke mine as well. What I did is move it to the motor mount as onasled suggested. You'll have to aug*sp* out the inside of the connector or if you can find one that fits you could recrimp it. It's been hooked up like this for about 2 months with out any side effects that I can tell.
Old May 8, 2005 | 12:53 PM
MyPocketRocket
Here what I did.
Old Jul 6, 2005 | 03:08 PM
GrnGbln's Avatar
GrnGbln
speaking of ground wires, does anyone know where i can get a good aftermarket one?
Wohnson89
Jun 10, 2020 04:53 AM
silence2-38554
Nov 12, 2015 09:39 AM
Minibeagle
Aug 13, 2015 10:00 AM
minipopkart
Aug 13, 2015 05:22 AM
