What does it mean when .... brake wear
Stuck caliper perhaps? Caliper not *sliding* properly on pins causing the outside pad to stay in contact with the rotor.
Any photos?
Any photos?
Originally Posted by onasled
Talking about rear brakes here.
What does it mean when your outside pads wear faster then your inside pads? Anything ?
Thanks for the thoughts guys. I ordered a set of brass bushings this morning so I'm hopping that this is in fact the problem.
The wear difference is not huge, but visually noticable. One side (of the car) is worse then the other.
This is the way the brakes wear on my civic as well, perhaps it's caliper design? On pad stationary, while one pad does the squeezing? I dont know about the mini's calipers, but with the civics on side gets pushed on by a piston, while the other just stays put. That is what I thought caused my wear differences...
Interior/Exterior Unboxing Video of Sneed4Speed R53 Brake Cooling Kit
Gremothra
Sep 9, 2015 08:42 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
