M7 AGS Now available for pre order.......
Old Apr 9, 2005 | 12:38 PM
M7's Avatar
M7
Team M7 is proud to finally being able to offer
the "Air Gain System" (AGS) for sale. We will
begin to take preorders for this exceptional
system and the first batch will ship April
22nd...
When I originally started to work on the AGS, I
thought I would have a final system available
within months... I was wrong big time, and for
that I apologize.
The first shipments will go out sans heat shield,
as we decided to move away from the low-tech
approach of a steel heat shield. The forth-coming
shields will be composite material, either black
gelcoat fiberglass or carbon Fiber.
The change-of-heart regarding the heat shield
really follows the original "Think outside the
box" approach of the AGS, and will allow us to
better contour the shield for this application;
and with that, provide more cool air to the AGS
filter.
Here's a breakdown of what will come in the box:
* 12" Hose 1/2" ø
* AGS tube
* AGS insert
* AGS Filter
* T-bolt Clamp (1pc)
* Small clamps (5pcs)
* Medium wire clamps (2pcs)
* Hose connector (1pc)
* 3' Hose 3/16 ø
* Elbows 90º for AGS (2pcs)
* Throttle body elbow CNC aluminum (1pc)
* M7 Aluminum label (1pc)
* Wiring harness jumper 7" (1pc)
* Vacuum adapters for MAP sensor and VAC booster
and 24" of vacuum hose
* AGS filter to crank case vent adapter elbow (1pc)
* Radiator hose heat shield blanket w/3 cable ties
* Radiator hose extension with adapter and (3) hose clamps
* Red bolt Cap to prevent chafing of TB
The system was conceived to allow installation
without cutting any wires or any other stock
parts.
As for installation...yes it's harder then
installing your run-of-the-mill MINI intake, but
with that said, we have gone to amazing lengths
to allow the system to be virtually plug & play.
To make life easier, we will deliver the system
with a very complete full color install manual
allowing you to do the job in hours, as opposed
to days. Further guaranteeing your success, our
"Tech line" is staffed with a live person 7 days
a week. M7 understands that great products are
one thing, but minus anything less then superb
support, well, that's not acceptable.
And better yet, this innovation and support comes
with very reasonable pricing:
Price: M7 AGS no heat shield $246.00
Price: M7 AGS w/ heat shield $299.00
available in approx 3-4weeks
Price: M7 AGS pro w/ heat shield and 62mm TB $599.00
Peter
Team M7
562-608-8123
www.m7tuning.com
02miniSguy
Nov 17, 2015 10:29 PM
Alpha Motoring
Nov 10, 2015 07:08 AM
vulkandino
Oct 31, 2015 08:29 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
EVMini
Sep 28, 2015 10:20 AM
