Avon Tech R in 225/50-16
Old Apr 4, 2005 | 08:21 AM
Craig_N's Avatar
Craig_N
Anyone successfully running the Tech R's in 225/50-16's? My 2005 MCS is running G Stock - not lowered, stock shocks, will I run into rubbing problems?
Old Apr 4, 2005 | 08:30 AM
satay-ayam's Avatar
satay-ayam
I think that size would be bad for gearing, and MAJORLY hard to mount.
I helped my friend try to mount my 215/40/16 V710's on my SSR comps saturday, and we got a schooling. NOT fun. However, the taller sidewalls may make things easier than the 40 series kumho.
Old Apr 4, 2005 | 09:26 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For SCCA solo II G-stock class using X-lyte 16x6.5" rims the Avon Tech R 225/50-16 ($160-175 each) tires will fit. The tire fits rims from 6 to 8" wide, weighs 20 pounds and has a taller than stock outer tire diameter of 24.9" which is not so good for gearing. You won't get rubbing due to the stock suspension having plenty of clearance.
For Kumho V710s there are not much that will fit 16" rims for the MINI.
215/40-16 ($159) tires fit rims 7 to 8.5" wide weigh 19 pounds and have a small outer tire diameter of 22.6" (good for gearing) but have a lower than recommended load rating of 1047 pounds (ok only for autocross with one person if possible). ($171 each for V710 in 225/50-16)
Kumho Victoracers come in 225/50-16 shaved for $160 ,outer tire diameter 24.5" 25 pounds
Kumho V700 come in
225/50-16 shaved for $153 each, 28 pounds per tire
205/45-16 low load rating of 1074 pounds, 24 pounds per tire, outer tire diameter of 23" (good for gearing) $143 each shaved.
Another option is 215/45-16 Falken Azenis Sport tires- they aren't as good as R compounds but better than street tires and they cost less about $100 each. See edgeracing.com
GregoryK
Dec 14, 2015 01:34 PM
boholio
Nov 9, 2015 03:50 PM
gnhovis
Sep 28, 2015 10:56 AM
rikaro
Sep 21, 2015 06:57 AM
HJCPmeek
Sep 15, 2015 01:59 PM
