R50/53 65K Mini has intake valve leak
Old Apr 25, 2026 | 01:05 AM
R53miniUK's Avatar
R53miniUK
Im not a mechanic but i have been learning, i did a compression test and a leak down test and found that cylinder 4 has zero pressure and the air is leaking out the intake port on the supercharger.
I have assumed this means the valves are not sealing, I haven't taken the head off yet im learning the process. can i get 2 new valves and do the lapping thing?
or should i remove the head and take it to a shop (im in the UK if anybody can recommend a place)
Thanks any extra advice is appreciated.
Old Apr 28, 2026 | 07:57 AM
ED955S's Avatar
ED955S
Maybe try running a BMW/Mini specific diagnostic OBD scanner tool to confirm the leaky valve before taking off the head. It should show misfire and poor fuel trim data.
Old Apr 28, 2026 | 02:51 PM
R53miniUK's Avatar
R53miniUK
ill try that tomorrow. i ordered a cheap OBD2 and it was delivered today. do i need a BMW version?
Old Apr 28, 2026 | 04:12 PM
ED955S's Avatar
ED955S
@R53miniUK , give it a try if a generic scanner will pull the misfire code.
I have BMW/Mini specific scanner iCarsoft 910 and Thinkdiag TKD01 that have deeper functions than generic ones
Old Apr 28, 2026 | 04:22 PM
noodlesandsam's Avatar
noodlesandsam
How well does it run ( if at all ). Yes, get codes - P0304 is misfire on cyl 04. A basic reader will give you that
Old Apr 29, 2026 | 03:21 PM
ssoliman's Avatar
ssoliman
if i were you i'd go all the way. engine rebuild or purchase and install a used engine from junk yard / allmagautoparts.com
you could also purchase rebuilt engine from pro shop. there are several online
Old Apr 29, 2026 | 09:34 PM
LukasH's Avatar
LukasH
I would take the head off to see what's going on. Best case would be a burned valve. Worst case the head and cylinder wall are destroyed.
In the UK Torque Monkey is a reputable place to go for Minis.
TSR53
Jul 29, 2014 01:49 PM
lukasbmw
Nov 23, 2013 06:41 PM
